As the pressure TANK only holds the liquid under pressure, you now have two good tanks.Did you adjust the pressure switch or check it for operation?Either adjust it or change it with a known good one.
Depending on the problem. If there is no mechanical problems check valves and piston seals would make it like new. If there is any damage replace pump.You can get parts at www.pressure-washer-parts.com They offer parts, or a giant brand replcement pump. GOOD LUCK
Hi.
This pressure washer is equipped with a
microswitch sensitive to water flow. This
Instant Start/Stop switch (ISS) senses
water flow in the pump. When the trigger
is released, water stops flowing
through the pump. The ISS then automatically
turns the motor off to protect
pump from overheating.
Initial Use of your Kärcher pump All Kärcher pumps ship with oil already inside direct from the factory. There is no need to add oil. Pump Inspection You should routinely make a visual inspection of the pressure washer's pump. If you notice oil leaking around the pump seals, you should take the pressure washer to a Karcher-authorized service center for repair. [Locate a service center in your area] Pump Maintenance The pump on your Karcher pressure washer does not require maintenance. Any attempts to service or alter the pump may damage your pressure washer and void your product warranty.
if the oil is dismantled by mistake -------- Oil volume required is in that caSE is --- as per the manual it says -=--------- 130ml.------------ Oil part # -------6.288-050---- thanks.
Question edited for correct spelling of maker 'Noen' to 'Moen'.
'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Well, we can have a one on one seminar by the internet. I've been a pumpman for 20 years. I can share with you my experience (household pumps, suibmersible pumps, turbine pumps, gear pumps, piston pumps, dewatering pumps, mud pumps, trash pumps, mining pumps, solids handling pump, etc....) Just take your pick. Just send in your e-mail for assistance. God bless.
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
