20 Most Recent
Dell 1700n Laser Printer Questions & Answers
DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Keep getting "Printer Offline" from Dell 1700 printer
go to the start menu
click on run
type services.msc
on the list go to Print Spooler
double click on print spooler and select automatic on startup type
now press on start.
if that doesn't work go to this microsoft website and click on the Fix It icon with the little man holding a wrench. run this and it will fix it.
Keep getting printer offline from Dell 1135n
1, There are several reasons that cause your Dell 1135n printer to be in offline mode. It might happen if the software is being updated on your computer, a connection issue might be present between your printer and computer.
2, A firewall or software is causing a communication problem. To resolve this error, open the Control Panel and locate the Device Manager Settings on your computer. Navigate to the USB's controller menu and select the plus symbol to open the list. Right-click on the USB Root Hub and choose Properties from the tool box.
3, Click the Power Management tab and uncheck it next to Allow the computer to turn off this device to save power option. Restart your PC. If the issue did not resolve, update the printer firmware.
For more printer related queries just give a call @ 1-866-293-9220.
Dell 1700 Flashing Lights
1) Turn on the printer and hold the resume button. Keep holding the button until it stops blinking and they begin to flash with a sequence.
2) After holding them, release the cancel button to reset the printer. After doing this, the printer gets resetted completely and the flashing lights stops.
Dell 1700n paper jam
Most larger printers like yours have an optical sensor that needs to have the paper pass by in order for it to send the "sent" signal. If the paper doesn't trigger that you get the paper jam error. look at this page http://www.fixyourownprinter.com/forums/laser/47953#1
it will tell you what and where to check for your problem. It has photos and videos. I hope this helps some.
Will not feed paper to print
Do a Mr. clean act on all rollers coming in contact with paper. I use distilled alcohol and cotton and it has worked for me.
