20 Most Recent
Arris WA840G 802.11g/b (49832000100) Wireless Access Point Questions & Answers
Can't find IP address
You can get the ip-address by visiting this
http://www.ip-details.com/ .It's used to search and find ip address's,domain name host's whois information
including city, country, global latitude & longitude coordinates.
Motorola WA840G is Bricked
Assuming you have done the Upgrade correctly do the following:
Clearing the Web Browser Cache
After you upgrade, you may need to clear the cache to view
the upgraded Web page properly:
1 Open a Web browser, such as Microsoft Internet
Explorer®.
2 Select Tools\Internet Options.
3 In the Temporary Internet files box, click Delete
Files.
4 In the Delete Files dialog box, select the Delete all
offline content check box and then click OK. Click OK
again
To access the Web-based configuration pages:
1 Open a Web browser. In the URL field, type
http://192.168.40.1 (the router’s default IP address) and
press Enter.
2 At the Motorola Wireless Broadband Router login
window, type your user name in the User name box (if
you changed it from the factory default (admin) the last
time you upgraded).
3 Type your password in the Password box (if you
changed it from the factory default (motorola using all
lowercase) the last time you upgraded). Then click OK.
The Basic configuration page appears.
How do i change the system settings
To configure the wireless router, follow these steps : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Resetting fulbond wireless AP
problem solved when im using access point manager to accessed my wap.
the default password is "default". for unknown reason the wap seems cant be access thru http, even i enter the right password. the http page tell me that the password is wrong. But when i used access point manager from www.teletronics.com i can log in to the wap and configure it using the same password that i used on the http page.till now still dont know what's wrong with the wap.
since it's working fine im not trying to find out anymore.
the default password is working too on telnet and others but it still dont work on http page and i dont
see any configuration that restricted access to the wap thru http access.
Missing power supply
locate the bottom of ur AP and read the following u should find these values:
Voltage: described by volts EX: 5 v or 12 v
Amperage: described by amperes EX: 500 ma , 1 A,....
Polarity: whre is minus and plus
write these values and u can buy any power supply or power adapter based on these values if not sccseeful write me ill help u more
[email protected]
WA840G firmware went bad :(
Based on your post/description, I would assume that though you did not complete the upgrade, you were able to restore the WA840G to the original/old firmware. Second, you still wish to upgrade again but using a different method other than web configuration.
Perhaps you can try a telnet session to 192.168.1.1 or the default which is 192.168.40.1 or the IP add you have set it to if you have modified it before. I have successfully tried this on a LinkSys WRT54G & NetGear MR814V2. Might or might not work for you. "?" or help should give you the basic line commands.
But then again, if the system has crashed and the unit is bricked, that is a harder problem and you might be better off replacing the unit.
Hope this be of some idea/help. Post back how things are or should you need further information.
Good luck and kind regards.
Pairing Router to Extender.
Please double check that each of your products are compatible with each other by either calling Arris or Netgear. You also review the netgear setup instructions after you've made the call if they're compatible.
This is the phone number for Arris: 1-877-466-8646
Thank you.
I have an arris router with suddenlink. i can login but i can't change my ssid because everything's greyed out. how do i fix that?
This can be done -- I've done it to my Arris modem router interface from Suddenlink.Make sure you have your original modem/router login info (typically this is something like admin/admin, or admin/password). You'll need this info in case there is an error and you need to reset your device. If you do this simple step-by-step carefully you won't need to reset and you'll be able to use the password or SSID you prefer with your device.To do this, the page with the grayed out field(s) must have an Apply, Submit, or other button that saves changes on the page.DO NOT TAKE THIS LIGHTLY.IF YOU EDIT THE WRONG GRAYED OUT FIELD YOU MAY NOT BE ABLE TO USE YOUR MODEM/ROUTER.Only do this for Names, SSIDs, Passwords, etc. Do *NOT* do this for other values--things are grayed out for a reason.1. Use Chrome or Firefox.2. Log into your modem/router.3. Right click on the grayed out field (which you want to edit) and select "Inspect" from the small context menu that appears by your mouse cursor.4. A complex looking set of window panes will open.5. The code for the grayed out field you selected will be highlighted in one of those windows panes.6. In that code look for something like:disabled(or)disabled="disabled"7. Click on that little bit of code text.8. Delete only that text:disabled (or)disabled="disabled"9. As soon as you click out of the editor and back onto the page you'll see the gray is gone and you can change the text in the field which is now editable.10. Replace the SSID, password, key phrase, or other information you're trying to change with the information you want there.BE CAREFUL ABOUT SPECIAL CHARACTERS OR SPACES.THEY MAY NOT WORK.11. After you've changed the text to be what you want, tap the Apply or Submit button on that page.12. The page should refresh now and record the new information in the field(s).If everything goes south (perhaps because you used a space or character which wasn't allowed), it's okay. All modem/routers have a reset button.
Registration code to activate a telus arris box
my guess is you forgot your ISP owns it
no country stated, no ISP stated nor your purpose here.
no model told, ARRIS. box.
plug it in
call ISP
speak
done. (only they do that, not you, you must ask them)
I own my own modem but must call them to even replace my box.
they configure it and is locked to ONE SERIAL NUMBER
JUST LIKE CELL PHONES ARE.
