20 Most Recent
Sanyo Xacti DSC-S1 / VPC-S1 Digital Camera Questions & Answers
Blurred image on display panel itself
I already did answer this? But I forgot the point, If your lens is dirty (must be bad) you only can clean it with a special lens pen or a micro five cloth, if a special fluid is used. Never clean lenses with anything else, because the coating on the lens is easy damaged. When the coating is damaged, you never will get any clear pictures os videos.
All the picture in may
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos.
This article reviews and outlines several of the better ones.
Where can i find service
I found that Sanyo has an affiliation with Panasonic and Haeir in the Philippines, So you can check with their service center for Digicam, I got the phone number too; try calling, am going to drop by my Sanyo Digicam: tel no for Panasonic Repair 2842272 and 7067603; ara code is 2
System error
Take the Battery[s] out and leave overnight.
Re insert battery
or if rechargeable, charge them up.
Then to morrow reinsert- see what happens.
Lens stuck and displaying System Error"
the Lens mechanism has become damaged some how
a bit of grit a knock- whatever.
There is no self ix option- with out running the risk of further damage.
Go onto the Sanyo tech support team and see what they say
A repair can be as costly as replacing the camera - be prepared for this
Why won't Sanyo Xacti camera does not power on after being charged?
not car moved this to camera
no model told at all
the batteries are no good or connections rusty on most
many of these are 13 years old and sold as new by liars endless on the web .
models
vcp-nnn (lots )
DMX-nnn (lots)
the endless list is here.
what it uses inside who knows lacking model
the battery is bad, or allowed to leak and damaged connectors.
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.The manual is still online.Success
How to get my picture right side up
I'm thinking you mean it is upside down on the camera screen. ??? Old man told me one time. When you get tired of trying to make that thing work right - read the instruction.
