20 Most Recent Sanyo Xacti VPC-S60 Digital Camera Questions & Answers
If it is still under warranty, return it to the shop where you bought it.
Sanyo Xacti... | Answered on Jan 23, 2018
Do a system reset. Also, make sure the battery is fully charged. Pull the battery out then replace after 30 seconds.
Sanyo Xacti... | Answered on Nov 17, 2017
Imnot sure what ya meant by this ..but to edit a video you have to first download it on the computer via data cable ...or from the SD card directly into a card reader ..than use whatever program you have for video editing ...
there can not be any video edition on a camera this size...even if there is ...is resuming on copy paste ...or changing the name ...for advance editing you have to get it on the computer
Sanyo Xacti... | Answered on May 21, 2013
While viewing the picture, press cursor-up. See the "Erasing files" section of the manual (page 37 in my copy). If you need a manual you may download a copy here.
If you want to delete all pictures, format the card. See page 95.
Sanyo Xacti... | Answered on Dec 14, 2012
Set the White Balance(WB) to daylight. Set the Contrast to 0 and ISO speed to auto..Flash mode off .Do you get the same result? For details, refer to the users manual: http://www.mediafire.com/?e9a69bedmwvfb0w
Note: PDF manuals require the Adobe Acrobat Reader for viewing and printing. http://get.adobe.com/reader/
Sanyo Xacti... | Answered on Aug 24, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Sanyo Xacti... | Answered on Aug 17, 2011
it is a CCD failure try to contact Sanyo they might change it free of charge as other companys are also doing it is a manufacturing fault in CCD units see the link try it email them i am sure they will do it free of charge
http://www.imaging-resource.com/badccds.html
tell me ur region i will fwd u a link for support
pls rate me FIXYA for help
Sanyo Xacti... | Answered on May 08, 2011
Open your picture by browsing mode (play back). And then open the menu there is a faction of copy, and you can choose all of the picture and copy them to your card. Have a try and to see if it's helpful
Sanyo Xacti... | Answered on May 06, 2011
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sanyo Xacti... | Answered on Apr 12, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Sanyo Xacti... | Answered on Feb 13, 2011
Hello.
The chip/one of the ribbon inside the camera has a possible scratch in it.
Firstly, try to connect it to your PC and look if there's any update available online.
get it update, if there is.
If none is available, flash the camera to a dark and light places and check if you can still see the horizontal lines.
If you can see the lines, it means it needs to be repaired.
Sanyo Xacti... | Answered on Nov 12, 2010
The problem is more complicated to resolve at home.Ask a friend skilled in electronics or go to service center (too expensive)
Sanyo Xacti... | Answered on Sep 30, 2010
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Hi, you have problem in camera software and need to be update or upgrade the said software. bring to service center and request for upgrading it is a minimum charge to be done on your camera. But i hope software will solve you problem because if its not the Main pcb is damage and need to be replace.
good luck and thank you
Sanyo Xacti... | Answered on Aug 10, 2010
In my opinion,it is due to you haven't choose the right video format.
Video Download Studio can help you with this very well.
get a free trial from http://www.downloadvideos-convert.com/download-videos-music
VDS converts your video into any kind of video format ,including formats AVI, MPEG, MP4, 3GP, WMV, MP3, FLV, MOV, WAV etc.
Sanyo Xacti VPC-S60 Digital Camera Logo
86 questions posted
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
Xacti Sanyo
  • Xacti Sanyo
Most Popular Question
horizontal lines appear photos taken
  • Cameras
