Intel Computers & Internet • Uploaded on Oct 06, 2013
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small + you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administration tools tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers
if you dont have a disk with the drivers you have to download themHope this helps
make sure that your RAM modules and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
graphics card is seated properly with no dust in the socket you might have to remove it to check for dust
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error hope this helps you
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive)) make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
52 questions posted
4,857 Questions
1,171 Questions
1,019 Questions
802 Questions
712 Questions
