20 Most Recent
Google Android 4.0 7 inch 1080P Video Capacitive Screen 16GB Tablet PC Questions & Answers
The screen turned off and it wont turn back on!!!
The symptom you described may be due to the main battery being discharged. In many tablets, there are 2 batteries, one main and one used to keep memory intact during suspend mode. When the unit powers on, it turns on the backlight (probably the highest power drain of anything on the tablet) so you can see the icons on the screen. If the main battery doesn't have enough energy, the sense logic will put the machine back into suspend mode, and it will appear to go off. You should plug your charger in, and see if this fixes the problem. If it doesn't then you need to check the voltage of the charger with a meter. If you don't have a meter, you can buy then at Harbor Freight for around $5. With the meter on, and the charger plugged in, stick the red lead of the meter in the center hole, and touch the black lead to the barrel of the power connector from the charger, and you should read some volts. The charger should say on it somewhere it's output voltage. Hopefully you've marked your charger with what device it goes to because many chargers look the same and have the same power connector but are not in fact the same.
Making the screen brighter uses more energy. So if you were successful with your "sun" icon, you could have made the problem worse.
Display screen will not come on
Look in your manual and find out how to do a 'hard reset'.
If this info is not in the manual, take it back to the retailer and get them to do it.
How can u downoad music to a d2 tablet
Tyler....File format means the type of file the data was written to. For example, some Music is in MP2 or Mp3 for example. WMA is another. You must know what format your tablet understands in order for the tablet to translate the song in to a playback mode. This information is in your operations manual that came with the tablet.
Android Tablet wont turn on.
CONNECT TO POWER SUPPLY .... PRESS ON BUTTON (20 SEC) THEN ... WITH OTHER HAND / FINGER KEEP TAPPING SCREEN .... REPEAT UNTIL TAB WAKES UP
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
