20 Most Recent Schwinn Ic Pro Indoor Cycle Questions & Answers
tip
How to Identify the Type of Bottom Bracket on a Schwinn IC Pro
Video about Identifying the Bottom Bracket on a Schwinn IC Pro Bike
  • This video will help easily determine what kind of bottom bracket you need for your Schwinn IC Pro
  • You see in the video there are four available
    • The first one showed is the OEM style bottom bracket, on both ends it is a square tapered shaft bottom bracket
    • We offer a Sportsmith bottom bracket kit including the crank arms and crank bolts
      • This is also a square tapered shaft bottom bracket
    • We also offer two ISIS style bottom brackets
      • One is a 1 7/8" diameter
      • The other is 1 3/8" diameter
      • As you can see in the video these both have a round splined shaft
      • To identify which ISIS bottom bracket you need you will want to remove the crank arm and measure the hole in the frame that the bottom bracket mounts into
  • You will have to determine if you need a round splined shaft or a square tapered shaft
  • If you do need the round splined shaft you will have to know if you need the 1 3/8" or the 1 7/8" diameter bottom bracket
  • Knowing these things can reduce the frustration of buying the wrong parts and shorten down time greatly
How to Identify the Type of Bottom Bracket on Schwinn IC Pro
Where does the electric plug attach for the schwinn 220 recumbent bike
https://www.manualslib.com/manual/571857/Schwinn-220-Recumbent-Bike-2012-Model.html#manual
9/2/2023 1:43:05 PM • Schwinn Exercise... • Answered on Sep 02, 2023
Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
3/17/2023 1:02:26 AM • Schwinn Exercise... • Answered on Mar 17, 2023
Schwinn recumbent bike 240 has E3 error code. Does not display speed, rpm or calories
My RPM sensor was defective and I replaced it with a similar one from ebay and that did the trick: Horizon Tempo Treadmill RPM Speed Sensor Reed Switch 2 Terminal Wire 002267-B (flat version)
3/17/2023 1:00:15 AM • Schwinn Exercise... • Answered on Mar 17, 2023
My Airdyne AD-6 crank arms are ~45* apart, not 180* Can they be adjusted?
It is possible that the crank arms are not seated correctly on the bottom bracket spindle, causing them to be misaligned. Try removing the crank arms and re-installing them, making sure that they are properly aligned with each other and with the bottom bracket spindle. If that doesn't work, there may be an issue with the bottom bracket itself, in which case it may need to be replaced. You can also check the manual for your Airdyne AD-6 to see if there are any specific instructions for adjusting the crank arms.
2/25/2023 7:45:16 AM • Schwinn Exercise... • Answered on Feb 25, 2023
Schwinn Airdyne AD6 clicking noise?
not a car , moved yah./
12/11/2022 6:50:54 PM • Schwinn Exercise... • Answered on Dec 11, 2022
Schwinn 701S Home Gym. How to assemble cables please?
Here are all the manuals and the manuals usually have the assembly instructions at the beginning. https://www.schwinnfitness.com/manuals.html It is available here at moderate cost ask the maker first. https://www.fitnessrepairparts.com/m/cart/ViewItem/13006172 ..
6/19/2022 12:10:30 AM • Schwinn Exercise... • Answered on Jun 19, 2022
2answers
ASSEMBLY INSTRUCTIONS FOR HOME TRAINER 730
Always consult a personal trainer for assembly instructions. It's interesting how a fit partner can help you assemble almost anything. If anyone is interested in finding out more, please refer to the following fitness specialists. They are true professionals. https://busybeefitness.ca/fitness-partner-toronto/ personal-trainer-toronto-jeimvor1n0gozo1hzllrbhlx-1-0.jpg
12/21/2021 9:44:31 AM • Schwinn Exercise... • Answered on Dec 21, 2021
How do you change the battery on Schwinn 430 elliptical? Where are they located?
Did you check the wheel? Usually it's under the wheel
4/20/2021 10:21:56 AM • Schwinn Exercise... • Answered on Apr 20, 2021
I have a Schwinn Personal Trainer 700. How heavy are the weights? What is the highest weight it can be set at?
sorry no clue as never needed a weight set to keep me fit
4/17/2021 1:44:15 PM • Schwinn Exercise... • Answered on Apr 17, 2021
Replace battery schwinn model 430 eliptical
Schwinn® 430 and Journey 4.0 Elliptical Fitness ... - Nautilus
download.nautilus.com > SCH.430.SM.EN.pdf
PDF Roller Wheel Disc (older models only). 48. 15 ... change between "BIKE" and Elliptical ("ELIP"). 9. ... Replace the Brake Assembly on the Schwinn® 430/470.
assembly manual / owner's manual - Nautilus
download.nautilus.com > AM_OM > Schwinn > SCH.4...
PDF Manual en Espa?ol Latino Americano: http://www.schwinnfitness.com. 430 / ... If replacement parts are necessary, use only genuine Nautilus replacement parts and ... PEDAL TO CONTINUE (if a bike) / STRIDE TO CONTINUE (if an elliptical).
Replacing The Console Batteries - Schwinn a40 Owner's ...
www.manualslib.com > ... > Owner's manual
The Machine Type switch (N) on the Console is preset at the factory to B (bike) or E (elliptical). If you replace the console,. it will possibly be necessary to set the ...
How to Replace an Elliptical Console - YouTube
www.youtube.com > watch 0:42 This video from Sears PartsDirect shows how to replace a console on an elliptical. ... Precor EFX 546 ... May 22, 2015 · Uploaded by Sears PartsDirect
12/5/2020 4:38:47 PM • Schwinn Exercise... • Answered on Dec 05, 2020
420 elliptical. What does E1 error code indicate?
check out the attached link
11/3/2020 3:25:03 AM • Schwinn Exercise... • Answered on Nov 03, 2020
Where are the batteries on a Schwinn 420 elliptical
I have attached the manual for the same.Go through it to find all details
11/3/2020 3:24:14 AM • Schwinn Exercise... • Answered on Nov 03, 2020
Model SRB-1800. Why is it indicating error code 1?
That error code is for the speed sensor. There is some kind of issue with it, it may be loose or misaligned, the magnet on the fly wheel may also be. Or the sensor may have failed entirely. You may check the sensor and the magnet but that will depend on your comfort level in taking the unit apart to get to the issue. What would you like to do?
9/22/2020 4:08:15 PM • Schwinn Exercise... • Answered on Sep 22, 2020
Hello I am looking for a user manual for a schwinn 330i Stair stepper I would greatly appreciate it
I searched the internet using https://www.google.com and could not locate a manual for that model Stair stepper. I did find a free manual for possibly a similar model 305p: https://download.nautilus.com/supportdocs/OM/Schwinn/SCH_305p_OM_web.pdf
6/5/2020 11:00:45 AM • Schwinn Exercise... • Answered on Jun 05, 2020
Hi, I am looking for a Schwinn 330i stepper /
post your email address and I'll send you the pdf.
6/4/2020 2:13:56 PM • Schwinn Exercise... • Answered on Jun 04, 2020
2answers
Schwinn 701s home gym assembly manual
6/1/2020 10:12:43 AM • Schwinn Exercise... • Answered on Jun 01, 2020
Schwinn 130 Journey 1.0, increasing resistance button, nothing happens
Our Schwinn 130 worked fine for a year then the resistance setting got stuck. We took it apart and found that the bolt that holds the magnet arm was too tight and preventing it from moving it to the highest resistance setting. We loosened the bolt a bit and added some WD40 and it works great now.
11/30/2019 7:13:00 PM • Schwinn Exercise... • Answered on Nov 30, 2019
Schwinn Ic Pro Indoor Cycle Logo
2 questions posted
Top Schwinn Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Schwinn Exercise & Fitness
Most Popular Question
error 3 e3 schwinn 240 recumbent bike
  • Exercise & Fitness
