20 Most Recent Schwinn Wide Ride Pedal Questions & Answers
Can't get a Schwinn dx900 to turn on I put in batteries
Question moved to Schwinn Exercise Bike. Here is the manual. Yes, page 8 refers. Put in the batteries and attach the wire. https://download.nautilus.com/supportdocs/OM/Schwinn/SCH_DX900_OM_web.pdf ..,
1/18/2022 11:28:20 PM • Schwinn Wide... • Answered on Jan 18, 2022
2answers
Square patterns start flashing on console and
follow this steps and fix it. God bless you Plug it in. The first troubleshooting step is always the most obvious. Your elliptical machine needs to be plugged in for the console to work. Ensure that the plug is securely placed into a grounded outlet and that the outlet is receiving power. Check that the circuit breaker has not been tripped.
  • 2 Reposition your hands on the handles. If your machine's monitor is not showing your heart rate, first reposition your hands so that you are touching the metal contacts. If necessary, clean the handles with a soft cloth to remove sweat or lotion residue. Do not grip the handles too tightly or move your hands excessively.
  • Sponsored Links
  • 3 Calibrate the ramp. If the ramp is not positioned correctly, it could need to be calibrated. Often this is done from the console. How you calibrate the ramp is dependent on the make and model of the machine. Refer to the owner's manual or customer service section of the manufacturer's website to find out how to reach the calibration settings on your specific machine. Many companies offer manuals in PDF format for download on their websites.
  • 4 Adjust the drive belt. Again, your specific make and model of machine will determine how you do this. Usually, you'll need to unplug the machine and locate the drive belt area. This is often beneath the panel housing the wheel and pulley. You may need to find a release latch or use a screwdriver to remove this cover. Refer to the owner's manual for your model to make sure you do not damage your machine.
  • Read more: http://www.ehow.com/how_6737713_troubleshoot-elliptical-problems.html#ixzz2gWAdfrgF
    2/22/2015 5:34:06 PM • Schwinn Wide... • Answered on Feb 22, 2015
    2answers
    Stairmaster 4000pt pedals lose resistance during workout
    THEIR IS A TRANSMISSION ASSEMBLY IN THIS UNIT THAT CAN FAIL.. TAKE THE SIDE PANEL OF INSPECT THE ALTERNATOR BRUSHES THEY MAY BE WORN THUS ALSO CAUSING THIS PROBLEM THE LATTER WOULD A CHEAPER REPAIR
    7/26/2010 2:12:17 PM • Schwinn Wide... • Answered on Jul 26, 2010
    Diamondback 1100es stepper has a squeak near the
    Penetrating oil does the job apply on all bushing let it sit then try the unit if you need to apply a bit more then do so.
    7/17/2010 5:52:42 PM • Schwinn Wide... • Answered on Jul 17, 2010
    Stepmill 7000 wont regulate speed
    Check the blue wire to the alternator. Check all connections. the blue wire is the tach wire. no tach signal and you cant climb fast enough!
    9/1/2009 5:47:39 AM • Schwinn Wide... • Answered on Sep 01, 2009
    Stair stepper won't start
    Wide Ride Pedal CTGID0 Stair stepper won't start
    4/12/2009 10:43:26 PM • Schwinn Wide... • Answered on Apr 12, 2009
    What can i do if the steps are continuously going in a non-consistent pace?
    Hi drlinders,
      You could hardly find any expert who deals with all this. More likely, you would not be able to find any information in outer world ( Internet ) regarding the same.
     The best advise would be to purchase a new one.A new wide ride pedal would cost you  $32.99.You can purchase it from amazon.com
    http://www.amazon.com/Schwinn-Wide-Ride-Pedal-2-inch/dp/B000F5NKZM
    Even if you contact the schwinn, more likely this would be the same advise from them.
     I know its really frustrating, but it seems to be the best solution at this moment.
    Thanks for using Fixya.
    4/2/2009 5:22:16 AM • Schwinn Wide... • Answered on Apr 02, 2009
    Stair Climbers screen won't work
    Wide Ride Pedal CTGID0 Stair Climbers screen won't work
    3/12/2009 3:02:20 PM • Schwinn Wide... • Answered on Mar 12, 2009
    Screeching stair climber
    Wide Ride Pedal CTGID0 Screeching stair climber
    12/1/2008 1:20:42 PM • Schwinn Wide... • Answered on Dec 01, 2008
    Stair climbers / steppers maintenance
    " * Read all maintenance instructions thoroughly before beginning work. * In some cases, an assistant is required to perform the necessary tasks, use all precautions. * The safety level given by the design of this equipment can only be maintained when the equipment is regularly examined for damage and wear. * Inoperable components should be replaced immediately or the equipment should be put out of use until it is repaired."
    12/1/2008 1:20:41 PM • Schwinn Wide... • Answered on Dec 01, 2008
    Where does the electric plug attach for the schwinn 220 recumbent bike
    https://www.manualslib.com/manual/571857/Schwinn-220-Recumbent-Bike-2012-Model.html#manual
    9/2/2023 1:43:05 PM • Schwinn Exercise... • Answered on Sep 02, 2023
    Error 3 (E3) on Schwinn 240 recumbent bike. How
    No speed/RPM reading, Console displays "E3" error code
    Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
    Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
    Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
    Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
    3/17/2023 1:02:26 AM • Schwinn Exercise... • Answered on Mar 17, 2023
    Schwinn recumbent bike 240 has E3 error code. Does not display speed, rpm or calories
    My RPM sensor was defective and I replaced it with a similar one from ebay and that did the trick: Horizon Tempo Treadmill RPM Speed Sensor Reed Switch 2 Terminal Wire 002267-B (flat version)
    3/17/2023 1:00:15 AM • Schwinn Exercise... • Answered on Mar 17, 2023
    My Airdyne AD-6 crank arms are ~45* apart, not 180* Can they be adjusted?
    It is possible that the crank arms are not seated correctly on the bottom bracket spindle, causing them to be misaligned. Try removing the crank arms and re-installing them, making sure that they are properly aligned with each other and with the bottom bracket spindle. If that doesn't work, there may be an issue with the bottom bracket itself, in which case it may need to be replaced. You can also check the manual for your Airdyne AD-6 to see if there are any specific instructions for adjusting the crank arms.
    2/25/2023 7:45:16 AM • Schwinn Exercise... • Answered on Feb 25, 2023
    Schwinn Airdyne AD6 clicking noise?
    not a car , moved yah./
    12/11/2022 6:50:54 PM • Schwinn Exercise... • Answered on Dec 11, 2022
    Schwinn 701S Home Gym. How to assemble cables please?
    Here are all the manuals and the manuals usually have the assembly instructions at the beginning. https://www.schwinnfitness.com/manuals.html It is available here at moderate cost ask the maker first. https://www.fitnessrepairparts.com/m/cart/ViewItem/13006172 ..
    6/19/2022 12:10:30 AM • Schwinn Exercise... • Answered on Jun 19, 2022
    2answers
    ASSEMBLY INSTRUCTIONS FOR HOME TRAINER 730
    Always consult a personal trainer for assembly instructions. It's interesting how a fit partner can help you assemble almost anything. If anyone is interested in finding out more, please refer to the following fitness specialists. They are true professionals. https://busybeefitness.ca/fitness-partner-toronto/ personal-trainer-toronto-jeimvor1n0gozo1hzllrbhlx-1-0.jpg
    12/21/2021 9:44:31 AM • Schwinn Exercise... • Answered on Dec 21, 2021
    Schwinn Wide Ride Pedal  Logo
    16 questions posted
    Top Schwinn Exercise & Fitness Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    David Kassin
    David Kassin
    Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
    View Most Popular
    • Schwinn Exercise & Fitness
    Most Popular Question
    stair climbers screen work
    • Exercise & Fitness
