20 Most Recent Targus Wireless Mini Optical Mouse Questions & Answers
I can not install the
You can find drivers for almost everything at the manufacturer's website...however, it appears that most of the mice use the standard windows driver, so I'm also sending you a link for general installation and troubleshooting. http://targus.custhelp.com/app/answers/detail/a_id/646
6/15/2011 6:10:10 PM • Targus Wireless... • Answered on Jun 15, 2011
2answers
Targus Model PAWM002 optical mouse
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers make sure the lead from the mouse has a secure seating and the lead is not bad/faulty (if applicable) make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable) click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot in xp hope this helps dont forget to vote
2/28/2011 4:56:36 AM • Targus Wireless... • Answered on Feb 28, 2011
My mouse stopped working, it does move once in
The battery compartment can be accessed in this mouse (Targus pawm002e) by sliding off the top cover of the mouse.
It's not located on the bottom of the mouse, as usual, so it may be hard to figure out at first.
Good luck, and please come back with a rating/testimonial if helped :)
7/24/2010 5:33:26 AM • Targus Wireless... • Answered on Jul 24, 2010
I plug the mouse sender in the USA of my acer
Yes you will need a driver.
Are you using Vista there is a link at the top of this page...
http://www.targus.com/us/support_downloads.asp
AndystUK
8/30/2009 1:48:20 PM • Targus Wireless... • Answered on Aug 30, 2009
How to open a Targus Chill Mat Pad AWE61US N2953
Without specific details about the type or model of the mat you're referring to, it's challenging to provide precise disassembly instructions. However, I can offer some general tips that might help you access the inside of the mat for cleaning without causing damage:
  1. Consult the Manual: If the mat came with a user manual or assembly instructions, refer to these documents first. They often contain disassembly guidelines or tips for cleaning.
  2. Look for Access Panels or Fasteners: Many mats or fitness equipment have access panels secured by screws, clips, or fasteners. Carefully inspect the mat's exterior for any visible fasteners or panels that might provide access to the inside components.
  3. Check for Removable Parts: Some mats might have removable parts like covers or casings designed for cleaning purposes. Gently try to detach these removable components, following any instructions in the manual or indications on the mat.
  4. Contact Manufacturer Support: If you're unable to find a way to disassemble the mat safely or if you're concerned about causing damage, consider reaching out to the manufacturer's customer support. They can provide specific guidance on disassembly and cleaning for your particular mat model.
  5. Online Resources: Look for online resources such as instructional videos or forums where individuals might have shared tips or experiences on disassembling and cleaning similar mats.
Always approach disassembly cautiously to avoid causing damage or voiding any warranties. If you're unsure or uncomfortable about disassembling the mat yourself, seeking professional assistance from a technician or contacting the manufacturer for guidance might be the best course of action.
12/17/2023 11:49:21 AM • Targus Computers... • Answered on Dec 17, 2023
.Yo I have a Targus ipad keyboard case that is cracked open in the back
1. remove all screws 2. buy white glue epoxy 3. mend all broken sections 4. fix them back and screw them after they dry
8/13/2022 3:29:43 PM • Targus Computers... • Answered on Aug 13, 2022
Looking for a targus apa01 wire diagram to connect to computer
Contact Targus directly to request the wiring diagram.
10/19/2021 12:43:00 AM • Targus Computers... • Answered on Oct 19, 2021
I have a targus bluetooth speaker mid#2550913 for got the pin
Try 0000 or 1234
6/26/2020 10:14:08 PM • Targus Computers... • Answered on Jun 26, 2020
Targus BEU0564C driver
Try Snappy Driver Installer - Install and Update Drivers is Free and no Ads or Malware https://sdi-tool.org/
2/27/2019 1:15:11 PM • Targus Computers... • Answered on Feb 27, 2019
Where did i get targus presentaion USB Stick
I found one on Amazon. Wireless Presenter, ON THE WAY RF 2.4GHz Wireless Presenter Remote Presentation USB Control PowerPoint PPT Clicker. see the link below. https://www.amazon.com/Wireless-Presenter-WAY-Presentation-PowerPoint/dp/B06Y5ZGPX1/ref=sr_1_1_sspa?ie=UTF8&qid=1542643943&sr=8-1-spons&keywords=targus+presentation&psc=1 presenter-bzex1t3xi1odt41tgkzajjgr-5-0.png
11/19/2018 4:16:20 PM • Targus Computers... • Answered on Nov 19, 2018
4answers
How to install epson stylus
I have the same printer; first need install the drivers, according woth your OS (Operative System), this drivers can find and donwload from this link: printers_and_all_in_ones/Epson_Stylus_T13
Just select your OS and donwload, install the driver and follow the guide step by step.
Good luck.
11/13/2018 6:02:03 PM • Targus Computers... • Answered on Nov 13, 2018
Print from targus tablet
google targus with make model and serial and go to support/download and get user manual.pdf
9/30/2018 8:36:14 AM • Targus Computers... • Answered on Sep 30, 2018
Targus Wireless Mini Optical Mouse Logo
Popular Tags
16 questions posted
Top Targus Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Targus Computers & Internet
Most Popular Question
targus model pawm002 optical mouse
  • Computers & Internet
