20 Most Recent
Toshiba Satellite P25-S507 Notebook Questions & Answers
What is the largest hard drive supported by
The specs say that you have a 60Gb. hard drive. If the unit is less than 2 years old, you should be able to install a 200-300 GB. hard drive without any issues. The older laptops have a 137 GB. limit on hard drive partition space. You still can put a larger capacity drive, but you will have to partition the drive into c: 137GB, then the second partition can be any size.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2/1/2011 11:01:08 PM •
Toshiba...
Answered
on Feb 01, 2011
Can i download the toshiba cd through the net
Yes, you can always download anything from anywhere from the net except some sites like napster whcih are menat for US & Canada.
Here is the Page link from Toshiba site:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=430219&rpn=PSP20U&modelFilter=P25-S507&selCategory=3&selFamily=1073768663
Copy this link in your web browser and select your operating system, and download it.
12/24/2009 11:21:36 AM •
Toshiba...
Answered
on Dec 24, 2009
How do you remove the keyboard to replace it with
Removing the Keyboard
To remove the keyboard, first remove the battery pack, then follow the steps below.
1. Open the display panel.
2. Insert a thin tool into each of the narrow holes in the strip cover and lever the strip cover up to release its latches.
3. Remove two M2.5×3 silver screws securing the keyboard.
4. Lift the keyboard out and place over the display hinges, revealing the keyboard cable.
5. Disconnect the keyboard cable and remove the keyboard.
Below is the link for your service manual for future refernce. It is free to copy, print and use.
http://tim.id.au/laptops/toshiba/satellite%20p20-25.pdf
11/19/2009 11:55:28 PM •
Toshiba...
Answered
on Nov 19, 2009
I've got benq joybook 5000U, the problem is
I think it is shutting down to protect from overheating. Do you live in a hot climate? It is best to turn off for a while to cool down the circuitry. You can set it not to reboot when this occurs: start> controlpanel>performance&maintenance>system>advanced>startup&recovery>settings
10/13/2009 6:13:07 PM •
Toshiba...
Answered
on Oct 13, 2009
My laptop kept on dumping my physical memory and
reinstall and format ...save files...its bugged...specially if you know that its kinda new and can not be anything wrong with the ram memory
also you might need to upgrade the Ram memory if you are running programs that ask for large resources
10/7/2009 5:54:34 AM •
Toshiba...
Answered
on Oct 07, 2009
How do I replace the keyboard?
The solution you presented was very helpful, even though it did not directly address the problem I had. I was able to determine the solution to the problem I had. Thanks!
9/11/2009 9:12:24 PM •
Toshiba...
Answered
on Sep 11, 2009
I have a benq joybook 5000U, and it started to
yes most likely its power supply issue so get it checked.
Before that, check the Fan at the base, is its revolving ok Or looks like there is some obstruction. if its revolving speed is not ok or not smooth then get it rectified.
7/14/2009 6:57:05 PM •
Toshiba...
Answered
on Jul 14, 2009
Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
4/1/2009 7:45:22 PM •
Toshiba...
Answered
on Apr 01, 2009
I can't read my screen because it it too llght
You should have a Fn button on your laptop, and pressing that, combined with the button that has a sun on it should raise your screen brightness, if your screen only has one brightness setting, and it got much darker all of a sudden, your LCD lamp probably went out, in which case it is probably better to buy a new laptop, because those are expensive to replace.
2/26/2009 8:56:25 PM •
Toshiba...
Answered
on Feb 26, 2009
