20 Most Recent Toshiba Satellite A55-S306 Notebook Questions & Answers
Ok, so i logged out
old post JAN 18' , let me guess the shop wants 5 times value just to tell you X is bad. right? GeekSxxxd.? sure it was ok before , all things are really. but not now, but sure you did not buy it broken, that is good clue. first off , all laptops made have this huge battery and all this old are bad and worse shorted so get that battery out first. simple , no? remove it and run on AC power pack for eternity if you want to. I guess this is black screen of Deathh(sic) post. 100% never ever shows text, even doing the long reset with power. the next step on any LT, is to carbon14 date it, (build year) it is very old, 14 years old today. with old old Pentium M processor. all PCs this old have CCLF backlamps. that all died years go. in fact most died, at about 2010 year, ok?> the lamps go dead after only 20,000 hours of use. we throw these PCs away. for 2 reasons. 1: huge labor and cost to replace those lamps. 2: and PC has no street value, at all. $23 used on ebay busted. here is the magic flash light test for all old laptops works on deal lamps from year 2000 to 2010 2010 is LED back lamp born day. power on, the fan must spin, heard and MUST Blow are or the LT will overheat. the use the flashlight like this. to see if you see data there. if yes,bingo, CCLF failure. http://www.pcdied.com/monitors_and_screens/flash-light-trick.html
8/26/2018 1:31:37 PM • Toshiba... • Answered on Aug 26, 2018
Video controller driver
go to http://support.toshiba.com/support and update you display with the lastest driver update.
9/23/2013 1:47:05 AM • Toshiba... • Answered on Sep 23, 2013
BATTERY LIGHT FLASHES AMBER
I think when I Toshiba laptop does this it is indicating the battery is extremely low or not charging correctly. I would try either charging or changing the battery.
1/7/2013 9:30:32 AM • Toshiba... • Answered on Jan 07, 2013
My wireless and sound does not work after recovering and upgrading to windows 7
Use a driver scanner to download drivers for hardware.. Also use a system utility tool like Reginout to fix windows errors. It might be be due to corrupt registry files.
4/16/2012 11:12:52 AM • Toshiba... • Answered on Apr 16, 2012
What do i do when my sister hates me?
Get your sister to contact FixYa and tell them you forgot your password and to send you a temporary, then go into your profile and change the temporary password to a new password of your choice.
2/14/2012 10:53:48 AM • Toshiba... • Answered on Feb 14, 2012
On a Toshiba satellite A55-S306 running XP. On
Here's the link to model-specific drivers:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Choose Product Support, then Show ALL models (instead of Show Current Models) and you'll be able to get to your particular model. Your Network Adadpter should be an Intel 10/100, or it could be WiFi card, and your modem should be a Toshiba Software Modem. Drivers are all there at Toshiba's site.
8/22/2011 1:37:59 PM • Toshiba... • Answered on Aug 22, 2011
2answers
I am having problems with
What you should do is in the following order:
1.Go into bios and load defaults (usually hit F1)
2.Go into bios and set the boot sequence as HDD number 1
3.Go into bios and disable network PXE boot if possible.
4.Now retry
5.No success press F12 and choose HDD as boot up
6.Now retry
7.No success then remove the HDD clean the contacts and reseat
8.Now retry
9.No success open the laptop lid locate which part of the laptop the hdd is located and just give the laptop a tap in that corner and abit of a push (with the laptop turned OFF) Ive successfully fixed 2 of my IBM's doing this.
10.Still no success try changing the HDD and reformating a fresh
11.Still no success i would open the laptop up completely remove the motherboard and oven bake your motherboard and 375f for 10 minutes BUT BE WARNED DO A GOOGLE SEARCH BEFORE DOING THIS!. This method can also repair other faults such as GPU faults, Memory faults..ect.
5/7/2011 8:57:56 PM • Toshiba... • Answered on May 07, 2011
Where is the CMOS battery located?
Unfortunately it is located inside the computer on the motherboard. It looks like one of those small round flat batteries that is used to keep information when the computer is turned off. Im sure you can find the screws under the notebook to open it up.
Good Luck,
kc
4/10/2011 4:33:43 AM • Toshiba... • Answered on Apr 10, 2011
Over heats and shuts down
When it is running, do you hear a fan? Sounds like the processor fan is not working. The fan might be connected.
9/4/2010 9:00:16 PM • Toshiba... • Answered on Sep 04, 2010
Why did my screen go blank
There are some problem in your graphics card so please repair or replace it from service center.
Regards
Ashly
2/2/2010 6:51:23 AM • Toshiba... • Answered on Feb 02, 2010
2answers
I donot have vga driver
Dear click on this link and download your driver free. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Good Luck
9/5/2009 6:17:30 AM • Toshiba... • Answered on Sep 05, 2009
Toshiba a55-s306 cannot get wireless to find
Toshiba has a program called "config free". Download it from Toshiba dot com and put it in the startup list. It will find your wired and wireless connectons.
8/8/2009 10:27:20 PM • Toshiba... • Answered on Aug 08, 2009
Screen is not coming on
If the system seems to boot OK (watch keyboard LEDs and drive light for activity), try to score an external monitor so you can check (via VGA connector) if the video section is working. If it is, then you have either a failed LCD backlight (fluorescent) or the inverter that supplies high voltage to it has died. The latter item is often on a small separate board that can be replaced independently of the main board.
7/25/2009 4:56:29 PM • Toshiba... • Answered on Jul 25, 2009
Overheating when plugged in to mains
their is a clear sign that the converter has gone corrupted ,,,,it is a hardware issue
7/22/2009 3:04:07 PM • Toshiba... • Answered on Jul 22, 2009
2answers
No Power Toshiba A55-S1063
sounds like the powersupply might be bad try another one if that dont help then your board is bad -sorry
6/30/2009 12:47:57 AM • Toshiba... • Answered on Jun 30, 2009
2answers
Toshiba Satellite A55-S306 scrubbed of malware-now wont run
No need to buy a recovery disk, since Toshiba allows you to download one online.
6/26/2009 10:42:25 PM • Toshiba... • Answered on Jun 26, 2009
Toshiba Satellite A55-S306 Notebook Logo
35 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
screen not coming
  • Computers & Internet
