20 Most Recent
Logitech Z-640 Computer Speakers Questions & Answers
My logitech z640 does not
Open the Sound control panel in the computer and verify that the output is set to external speakers. You can verify by playing with the System Alert sounds; this will weed out application problems. There are a few applications that have the sound output selection crossed up on some computer models - selecting the internal speakers will send the sound to the external speaker jack(s) and vice versa.
If you have headphones or a different set of speakers, try them just make sure the computer is not the problem.
My logitech z-640 speakers have
well you &hash39;s why do you think there is a short in the cord did you hear static?if you are having problems
with your sound
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question mark? Right click to reinstall
drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar
if his does not fix the
problem
have you tried this control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer
hope this helps
My speakers stopped working i
If you suspect your sound card, I'd need to know the model and make of your computer. If you can find out what kind of computer it is, often the manufacturers website provides you with the downloads. What you would need is an audio driver.
Getting sound from the two
you might need to select stereo speakers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
hope this helps
I need the same sound
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
My logitech z-640 speakers arent
The different connectors are for 5.1 surround audio, and are for different speakers with your system.
- The green connector is for your front-right/front-left speakers
- The black connector is for your rear-left and rear-right speakers
- The orange plug is for your center speaker.
Most laptops do not have support for 5-speaker audio, so if you want to test each individually, you will need to plug them in one at a time and test playing sounds through them.
Hope this helps,
I think I might have
If you can get around to the back of your PC they should be colour coded, green to green (speakers) pink to pink (mic) etc,
If they are not colour coded, play something and then get back there and move the port one by one until you hear it playing. You will definitely find the mic port easily as it should have a image of a mic stamped onto the metal by the port, its the speakers that are a bit harder to work out from the images
Let us know how you get on :)
I have installed the z
- Verify that all cables are plugged in correctly. Make sure the rear
and/or center/sub audio cable is plugged in to the correct port. On
most surround sound cards, the rear audio port is black, the front
audio port is green, and the center/sub audio port is orange. If you do
not have a surround sound card, make sure you obtain the proper adapter
(discussed in the next paragraph) or use surround sound emulation if
your speaker system offers it. If you are not sure if you have a
surround sound card, please check with the manufacturer of your sound
card for details.
- Make sure your sound card supports the same amount of channels as
your speaker system contains. For 4.1 systems, it should have a front
and rear speaker jack on the card. For 5.1 systems, the card should
have a front, rear, and center/sub, output. The card should be properly
installed and configured. Please contact your sound card manufacturer
for details. If you do not have a surround sound capable sound card,
you can use the M3D button on the controller unit (if you own a z-560
or z-540) or use the source selector switch (if you own a z-5300 or
x-620). If you do not have any of the models above, you can use an
adapter to split the signal for the front and rear speakers. This type
of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase
this adapter at your local electronic store. Please refer to your
manual if you do not know if your speaker system can emulate surround
sound.
- Try connecting the speakers to a portable sound device such as a
walkman or portable CD player. Plug the speakers into the headphone
jack, but make sure the volume is lowered so the speakers are not over
powered. You can do this for both the front, rear, center/sub speakers
to verify that they work. If the speaker system works on the walkman,
then you are experiencing a configuration issue with your sound card.
Please contact your sound card manufacturer.
- Check the system Volume Control located in the System tray. Make
sure that the volumes are at a reasonable level and are not checked for
Muting.
Post back!
