Xerox One Touch 2400 Flatbed Scanner
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Xerox One Touch 2400 Flatbed Scanner?
Troubleshooting and Support
Solved Problems for Xerox One Touch 2400 Flatbed Scanner RSS Feed Post a New Problem
XEROX One touch 2400 , PC does not...
Hi After trying to install the Scanner, using the step by step guide, first driver than connect..., unlocking it etc I...
2 Solutions
installation and drivers
i bought asecond hand xerox scanner but with out drivers.its xerox one touch 2400 flatbed scanner.thankx for your help/
2 Solutions
Xerox One Touch 2400 Flatbed scanner...
just bought the xerox 2400 flatbed scanner second hand and i just cant get to download the drivers for it simply i keep...
1 Solution
I dont have a driver
I need to download a driver to use on my mums computer she's lost the one that came with it. the link supplied doesn't...
1 Solution
Xerox One Touch 2400 - Problem please help
I acquired a Xerox One Touch 2400 Flatbed scanner yesterday. I had a problem installing it. I made sure it was unlocked....
4 Solutions
Xerox 2400
I have been given a Xerox 2400 scanner but no installation disk were do i get one from!!!!!!!
1 Solution
Unsolved Support Problems
Unsolved Problems for Xerox One Touch 2400 Flatbed Scanner RSS Feed Post a New Problem
flatbed scanner held up at 'warming up the...
My flatbed scanner ceases working although the light glows but does not scan executing the message ''warming up the...
Post a Solution
lost the disc
how can i install scanner
Post a Solution
I can't get my xerox scanner to work
It has worked before, but now i go to scan something and it says install or run device, but my device manager says that...
Post a Solution
XEROX 2400 SCANNER
When scanning a document it won't save to PDF format only jpg.
Post a Solution
hello
How are you doing........? Pls i lost my driver for xerox 2400 scanner,how can i get the software online here,pls you...
Post a Solution
Hi, I have posted my problem today on the above scanner. Are you able to help please?
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceUSB
Optical Resolution1200 dpi
Max. Resolution (Hardware)1200 x 4800 dpi
Max. Color Depth48-bit Color
Max. Gray Depth16-Bit (64K Gray Levels)
Technical Features
Form FactorDesktop
Light SourceCold Cathode Fluorescent Lamp
Input TypeColor
Media
Media Loading MethodManual Load
Max. Supported Media Size216 x 297 mm
System Requirements
Operating SystemMicrosoft Windows XP Home Edition · Microsoft Windows XP Professional · Microsoft Windows 98 · Microsoft Windows 2000 · Microsoft Windows ME
Dimensions
Depth11.9 in.
Height2.6 in.
Width17 in.
Weight5.5 lb.
Xerox Contact Information
Main support number1-800-821-2797
Sponsored Links
Loading problems.
Top Scanner Experts
tryit
6 solutions
Office Machines, Small Appliances
Ask Me
Guru
jackboy
3 solutions
Digital Cameras, Computer Hardware, Storage and Media...
Ask Me
Wiz
angelica
2 solutions
Operating Systems, Software Utilities...
Ask Me
Master
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
