20 Most Recent Panasonic TC-26LX20 26 in. HD-Ready LCD Television Questions & Answers
Tv/pc
Your Panasonic TC-26LX20 26 will only allow video inputs through the:
1. composite video/audio input ( RCA phono x 3 ) - front or rear
2. S-Video input ( 4 pin mini-DIN ) - front or rear
3. component video input ( RCA phono x 3 ) - rear
4. HDMI ( 19 pin HDMI Type A ) - rear
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output ( 4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Good luck and kind regards.
3/15/2016 9:13:02 AM • Panasonic... • Answered on Mar 15, 2016
My Panasonic TC-26LX50 TV every channels is a fish tank, how do I change that?
FISH TANK? What is it? Provide more details please.
6/8/2015 2:47:03 PM • Panasonic... • Answered on Jun 08, 2015
I have a insignia ns-pdp50hd-09 plasma tv that has sound but no picture
You may try using the power switch on the TV itself instead of the remote. I have had trouble where the remote turn on doesn't work for the video, holding down on remote button longer seem to help. Also you may want to try another input to the TV -so connect up input wires from your cable/sat to another one.
7/1/2014 6:49:56 PM • Panasonic... • Answered on Jul 01, 2014
2answers
No picture but has sound
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
8/8/2013 1:30:32 PM • Panasonic... • Answered on Aug 08, 2013
There are so many reasons for this fault. If you wish to know more, check the site linked here. It has details about troubleshooting to Panasonic TC****** series TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
7/15/2013 11:41:53 AM • Panasonic... • Answered on Jul 15, 2013
Check the back-light is present. If not, check and replace back light inverter board. http://electronicshelponline.blogspot.com/. If you wish to get more details, check this link. It has details about Panasonic TC-26LX series LCDs. Pull up older posts.
6/15/2013 5:28:44 AM • Panasonic... • Answered on Jun 15, 2013
42pa30rq
you can check the power light,if light burn,it is maybe main boards is defective,if not please check power supply.when you make sure which boards is defective,you can find this boards by pcb number on www.wisiny.com/
6/5/2013 9:48:56 AM • Panasonic... • Answered on Jun 05, 2013
42pa30rq 10000
6/5/2013 9:47:37 AM • Panasonic... • Answered on Jun 05, 2013
Lightning hit nearby now my Panasonic tc-l3232c has sound but no picture what could be the problem?
Two issues come to mind on LCD/LED TVs with a blank screen. First and foremost, unplug it from the power source for a few minutes, then plug it back in and power on to see if your problem has gone away. If not, then the easiest way to diagnose the problem is to power on your TV in a pitch black room (or drape a thick blanket over it and peek underneath at the screen while it's on)... we want to see if the backlights are working or not. If the screen looks like it's 'lit up' with a dark gray tint to it, then we have backlight and there is another problem. If no backlight, then your set has a bad backlight inverter. In either case, this will require parts replacement. Panasonic is very tight with who they will sell their parts to, unlike other manufacturers and usually require authorization from a technician before selling them.
12/21/2012 11:12:45 PM • Panasonic... • Answered on Dec 21, 2012
2answers
Televison Display Issue
PRESS LIGHTLY ON THE SCREEN. IS THERE A SLIGHT DISCOLORATION? IF SO THE PANEL IS ON AND YOU PROBABLY HAVE A MAIN BOARD ISSUE. IF NOT THE POWER SUPPLY, INVERTER BOARD OR PANEL IS THE ISSUE.
5/18/2012 11:43:41 AM • Panasonic... • Answered on May 18, 2012
Sound but no picture
Are you connecting your laptop to the HDMI port on this tv? In what circumstance is it not giving you any sound? Check the connections at the back - are they in the right place and the right order?
7/20/2011 5:05:19 AM • Panasonic... • Answered on Jul 20, 2011
The red Standby light does not appear on the front
If there is no indication of any kind then it shows that the main power supply of the TV has failed. So you need to remove power plug and check the power supply of the TV, remove back panel and check the SMPS.
Check this link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
5/7/2011 6:50:57 AM • Panasonic... • Answered on May 07, 2011
Diagram to hook up HDTV, Tivo with cable card, and
I did it myself. With 2 HDMI cables, it was easy.
1/20/2010 6:08:49 PM • Panasonic... • Answered on Jan 20, 2010
Can not figure this out
YOU NEED THE RIGHT REMOTE.
3/20/2009 3:37:50 PM • Panasonic... • Answered on Mar 20, 2009
Black screen with colored vertical lines
YPU HAVE A BAD PANEL. THE COST OF REPAIR WILL PROBABLY EXCEED THE VALUE OF THE SET.
3/20/2009 3:36:46 PM • Panasonic... • Answered on Mar 20, 2009
Grey cloud across the screen
Sounds like a backlight failure I suppose. It's a lot of work to fix them.
11/17/2008 5:02:48 AM • Panasonic... • Answered on Nov 17, 2008
2005 Panasonic LCD TV Model# TC-26LX20
I am also having problems with the same year and model number panasonic, it is at the repair shop now. I think it is a lemon tv. won't buy panasonics anymore. Tried all the fixes recommended by panasonic. It happens after the tv is on for longer than 1/2 hour. It happens with dvds and different hook ups. my samsung is fine on all the same connections.
11/16/2008 4:44:26 PM • Panasonic... • Answered on Nov 16, 2008
Panasonic TC-26LX20 26 in. HD-Ready LCD Television Logo
38 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
lightning hit nearby now panasonic tc
  • Televison & Video
