20 Most Recent
Panasonic PV-C1320 13 in. TV/VCR Combo Questions & Answers
I have a Panasonic pv-c1320
Here are some Panasonic codes that Comcast lists on their website: 21062, 20035, 20162, 20225,
20614, 20616, 21035
(but the code depends on which remote you have, check Comcast's website for more info)
http://www.comcast.com/corporate/customers/customer_support/remotes.html
You can also try to manually search for the code:
Turn the TV on
Press TV or AUX
Press and hold "Setup" until TV/AUX blinks twice
Enter 9911 and press "Power" using the Comcast remote
Press "Channel Up" until device powers off
Press "Setup" to lock in that code
Please let me know if you found this helpful.
Have a great day!
3/16/2011 9:33:55 PM •
Panasonic...
Answered
on Mar 16, 2011
What is the TV remote controller code for a
Hello
Universal remote codes for Panasonic TV/VCR combo are:-
0374 0381
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
3/4/2011 4:14:19 AM •
Panasonic...
Answered
on Mar 04, 2011
Panasonic TV Model PV-C 1320
There should be a TV/AV button located with the front control buttons, press this & it should switch over to the AV source ie. your camera input.
9/2/2009 11:52:32 PM •
Panasonic...
Answered
on Sep 02, 2009
No remote
The only thing that you are able to program without the remote is the language, channels, and time by pressing and holding the play and FF button for five seconds until the tv turns off, turn it on again and you will get what i just mentioned...
6/4/2009 9:22:17 PM •
Panasonic...
Answered
on Jun 04, 2009
I need the repair manual for this TV.
Here's a link to order the original Panasonic service manual for this model (PV-C1320) from a major parts distributor:
Panasonic PV-C1320 Replacement Part Service Manual
2/5/2009 7:42:15 PM •
Panasonic...
Answered
on Feb 05, 2009
Cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable box.so, what you are going to do is use the remote control of the cable box.
11/7/2007 5:37:15 AM •
Panasonic...
Answered
on Nov 07, 2007
Play games on tv
go to channel 1 if there is no audio/video switch or you can use the rf mudulator
11/7/2007 4:25:19 AM •
Panasonic...
Answered
on Nov 07, 2007
How many watts does the tv take, anybody know?
Here's the link for the user manual if you need it;
http://service.us.panasonic.com/OPERMANPDF/PVC1320.PDF
Check page 39.
120vac - power on = approx 69W
I wouldnt get an inverter too close to that figure, but a 200w inverter should do - just check the inverter specifications to verify if the rating is actual power output - many inverter manufacturers are a little creative with their model names etc, but the real info has to be somewhere on the box.
If in doubt then the best way is to evaluate your battery system capacity and usual recharging input, and match the current drawn by an inverter to half that figure, see what power inverter size you can manage. if you buy bigger, you get more watts per dollar usually, and you may want any surplus capacity later for another item.
Also running inverters up towards their maximum often will shorten their life dramatically.
Hope this helps :)
6/27/2007 5:36:41 PM •
Panasonic...
Answered
on Jun 27, 2007
VCR Chews up tapes
it happened to me too. the only way to fix it or take the vhs from the vcr is to open it.
6/27/2007 5:07:08 PM •
Panasonic...
Answered
on Jun 27, 2007
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
