20 Most Recent
Hitachi M2 Digital Camera Questions & Answers
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Camera keeps switching off, even with new batteries
hi there.
it could be the swtich of turning it on and off so much, i have a cannon and i used it so much that the gears that brings the telephoto in and out, i used it so much it wore out the gear( and it would shut of and not come back on to get the zoom in... and had to have it sent to the dealer and they fixed it for free. and works great.. so im guessing that this might be whats wrong with yours maybe . the swtich is bad or where you put your batteries in is not making good contact...or the right kind of batteries...you can type in google the name of camera and they have a sight that people post there question and maybe they can help you.. good luck
HITACHI HDC-531E
I have the same problem. My research suggests that a battery for the Konica Minolta NP-900 may do the trick. The dimensions and configuration look the same as that for the Hitachi HDC-531E.
I've ordered a cheap one from Hong Kong and will let you know whether it works once I've tried it out, Fingures crossed!
Hdc-570as wont switch on
ive just had the same problem and solved it first you have to plug it into the pc with the usb then just before it goes onto the menu for pc,bridge,and pc camera pull the lead out quickly as you can. the camera will stay on to allow you to the next step
go into the menu and click next menu and go to fr. no. reset. and click execute then go back to the second menu and go to sys. reset and click it the click execute.
once this is done turn the camera off wait 10 seconds then hold down the power button until it turns on
done
if you have trouble let me know and il guild you through it slowly
