20 Most Recent
Vivitar ViviCam 3750 Digital Camera Questions & Answers
Is a vivicam S130 downloading software the same as Vivicam 3750
Yes, but you don't need to use it. There are much better choices out there.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
I am trying to install
Consider NOT installing the camera onto the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Downloading pictures to your laptop
This is very simple:
Install any software that came with your camera (sometimes this can be optional, try it withought first)
Plug in your USB cable to your camera, then to your computer.
A box should come up to download the pictures. If not, look at this website:
http://www.chriscamera.com/downloadingphotos.htm
This is how to download photos manually (by copying them onto your computer)
With these steps, you should have your photos ready on your computer.
Be sure to rate macapplezoo 100% or whatever you think I deserve!
I can not download my
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
