20 Most Recent Vivitar ViviCam 5022 Digital Camera Questions & Answers
I have a vivicam 5022 and i accidently hit format
Format completely erases the card.
2/25/2021 9:20:23 AM • Vivitar ViviCam... • Answered on Feb 25, 2021
Download onto computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
9/21/2014 4:37:50 AM • Vivitar ViviCam... • Answered on Sep 21, 2014
How do you set date and time on vivicam F126?
Try clicking the middle round button and going forward until you ind date and then time. Click on them and you'll be able to set the date/time. My camera id the same but it's the s124. They're both similar and really works the same, exactly. It's just the different number. I hope this helps! :)
7/6/2014 7:24:37 AM • Vivitar ViviCam... • Answered on Jul 06, 2014
0answers
Download the installer
Do you really want the Vivitar software when there are better programs available for free? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
2/2/2014 4:23:45 PM • Vivitar ViviCam... • Answered on Feb 02, 2014
Software download
Do you really want the Vivitar software when there's so much better available for free? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
2/2/2014 4:22:06 PM • Vivitar ViviCam... • Answered on Feb 02, 2014
Date and time on my pic
The date and time (and a lot more) are stored with every pic in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1/25/2014 7:58:21 PM • Vivitar ViviCam... • Answered on Jan 25, 2014
How do put the time and on my pics
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1/25/2014 7:57:59 PM • Vivitar ViviCam... • Answered on Jan 25, 2014
It won't turn on for me
they work better with rechargeable
1/20/2014 1:07:16 AM • Vivitar ViviCam... • Answered on Jan 20, 2014
Is there any way I can get sound on my Vivitar
For the person who said this cam does not record sound you are wrong it is not the best but does record sound.
1/20/2014 1:06:42 AM • Vivitar ViviCam... • Answered on Jan 20, 2014
I can't turn it and i don't have a USB cord
Test your batteries and attempt to turn on the device. You shouldn't need to use a USB to USB micro slim cable
1/9/2014 8:56:21 PM • Vivitar ViviCam... • Answered on Jan 09, 2014
Buttons not working batteries
Check if they are the ones that fit to this exact camera. Sometimes cameras don't "read" random batteries and they have to be the one's that the manufacturer says (check the manual).
1/2/2014 5:27:03 PM • Vivitar ViviCam... • Answered on Jan 02, 2014
Won't turn on
Did you check if the batteries are inserted correct? + to + and - to - Also it could be you have the wrong batteries. Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to Ni-MH or alkaline batteries. Checking the voltage of every cell with a multimeter could tell you for sure the batteries are good. Voltage should be jus above the voltage printed on the battery when measured. Never use manganese (Zinc-Carbon) batteries, because they don't have enough capacity to let a camera work correct.
1/2/2014 2:57:08 PM • Vivitar ViviCam... • Answered on Jan 02, 2014
Fixed storage is full won't download pictures
try taking your sim card out of the camera, and put in your laptop. i hope that works.
1/1/2014 10:50:11 PM • Vivitar ViviCam... • Answered on Jan 01, 2014
When i make a video the sound dosent wor
The 5022 is designed as a still camera, with some video capabilities grafted on. As such it does not record sound. You can add a soundtrack using video editing software on your computer, but you cannot record one on the camera.
11/8/2012 10:12:01 PM • Vivitar ViviCam... • Answered on Nov 08, 2012
How can i see pics in this camera?
Press the Playback button (marked with a right-pointing triangle).
10/6/2012 5:32:03 AM • Vivitar ViviCam... • Answered on Oct 06, 2012
My charger does not work, I need a new one
Bear in mind that the Vivitar 5022 does not charge batteries. It uses standard AAA batteries. If you want to use rechargeables, you must charge them outside the camera using any AAA recharger such as those available at just about any department, electronics, or office-supply store.
10/5/2012 2:39:28 PM • Vivitar ViviCam... • Answered on Oct 05, 2012
Vivitar ViviCam 5022 Digital Camera Logo
242 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
set date time vivicam f126
  • Cameras
