20 Most Recent Sharp CD-BA200 CD Shelf System Questions & Answers
3answers
Problem with Sharp CD-BA200
I just called Sharp customer service line. I was told it's a "problem with the software"...whatever the hell THAT means, but it has to be serviced.
5/3/2015 11:46:41 PM • Sharp CD-BA200... • Answered on May 03, 2015
2answers
2answers
My stereo
Disconnect your speaker boxes. If the "protect" error goes, then the speakers or wires may be at fault. If the error remains, most likely the audio output IC is blown.
3/18/2015 8:02:54 PM • Sharp CD-BA200... • Answered on Mar 18, 2015
Why won't my unit turn on-front says goodbye
"Moved" is the keyword here. If the unit was knocked, then damage could have occured. This might simply mean a bad soldering joint that could be repaired with just a touch of a soldering iron.
12/1/2014 12:12:16 AM • Sharp CD-BA200... • Answered on Dec 01, 2014
0answers
0answers
Error 0308
Be the first to answer 1/19/2014 8:45:03 AM • Sharp CD-BA200... • Posted on Jan 19, 2014Be the first to answer
I got Speakers Sharp CP-BA200
Your CP--BA200 is as follows Black/blue is - +and your red/black is + -, and its just that simple...
5/30/2013 8:13:11 PM • Sharp CD-BA200... • Answered on May 30, 2013
Sharp CD-BA2100, when I turn
the rubber rope which conect the motor to a small gears to open the cd was cut due to long using ... this sound of clicking coz the small motor is running and its not attached to anything ... its a small rounded rubber rope ..the bad news is you have to break some plastic stuff to reach the motor in the repair depot they change the whole upper part so it costs alot ... but if you can reach it it will work perfect as its new.
1/21/2013 9:00:24 PM • Sharp CD-BA200... • Answered on Jan 21, 2013
My sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
3/15/2012 10:56:18 AM • Sharp CD-BA200... • Answered on Mar 15, 2012
Stereo displaying protect when turn it on
Protect is an error code for short and/or overload. It will appear once the processor sensed a malfunction either on the power supply or on the load (high chance is the output IC). DIY steps are as follow to determine where the fault is :
1. Allow the unit to cool down for an hour. Give proper ventilation and keep away all obstruction from the vent to have a sufficient air flow.
2. Disconnect one at a time the speakers, inputs, from the unit and then power it on.
If the unit resume its operation then you've confirmed that any of the above caused the error code. If #1 is the caused, you have to check also the exhaust fan (if installed), clean it as much as possible, replaced if faulty. If #2 is the caused (speaker) check the wire and speakers for short, (input) check the RCA cord for short or replaced if necessary.
If the steps above didn't resolve the symptoms, the fault is inside the unit and needs to troubleshoot by a qualified technician. I would advice you to contact your local Sharp service center and ask for an estimate to have an idea how much money you are going to spend sending the unit in. Freelance technician is another option, you can saved some money compare to service center's fee.
Also, check if your unit is under warranty period(1 year), if so, avail it because the manufacturer will fix it for free, opening the cover of the unit will void the warranty.
Hope I helped you.
Have a nice day!
Jdvillanueva
12/17/2011 12:22:31 PM • Sharp CD-BA200... • Answered on Dec 17, 2011
Sharp CD-BA200 CD Shelf System Logo
46 questions posted
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Audio Players & Recorders
Most Popular Question
got speakers sharp cp ba200
  • Audio Players & Recorders
