20 Most Recent Sharp Multi-System Mini Component System Shelf System Questions & Answers
My Sharp bh950 for some reason won't come on it used to work I rarely play it I noticed no lights were flashing so I thought maybe it was unplugged by accident but that's not the case I tried different Outlet it will not come on no lights nothing.
See if this applies as per another Sharp compact stereo? SPECIAL NOTES The mains lead of this product is fitted with a non-rewireable (moulded) plug incorporating a 3A fuse. Should the fuse need to be replaced, a BSI or ASTA approved BS 1362 fuse marked or and of the same rating as above, which is also indicated on the pin face of the plug must be used. Always refit the fuse cover after replacing the fuse. Never use the plug without the fuse cover fitted.
2/27/2021 10:12:16 PM • Sharp... • Answered on Feb 27, 2021
WHY THERE IS NO POWER WHEN I PLUG IT IN?
Hi I'm having trouble with my 5 disc component system 880 sharp mxp want make a sound like can you please tell me what to do
1/1/2019 6:28:42 PM • Sharp... • Answered on Jan 01, 2019
CD 3 DISC PLAYER MODEL ES222E
First place to troubleshoot for the above listed issues are the gears, if gear driven spindle, or the belt if it is belt driven. If gear driven spindle apply enough non-attractive lubricant to the gears so they function freely. If belt driven clean all surfaces that the belt touches to ensure all dust or debris is removed and then lubricate center spindle posts only so that they can rotate freely and with as little friction as possible.
8/28/2017 4:50:34 PM • Sharp... • Answered on Aug 28, 2017
0answers
2answers
I can not leave the
I was just having the same problem and figured out how to fix it. When the unit is off (in standby mode) hit the X-BASS/Demo button on the remote. This will solve the problem!
12/12/2016 11:52:17 PM • Sharp... • Answered on Dec 12, 2016
0answers
Where can I download an owner's manual for the Sharpe CD-E67 Shelf System
Google sharp cd-e67 manual you get a lot of options.
12/8/2014 9:19:37 PM • Sharp... • Answered on Dec 08, 2014
Unit has no power
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
11/2/2014 4:08:45 PM • Sharp... • Answered on Nov 02, 2014
I want to locate service center of aiwa in the
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=6&cad=rja&ved=0CG4QFjAF&url=http%3A%2F%2Fwww.callcenterbeat.com%2Faiwa-service-center%2F&ei=XXVpUvXqNIWKiQekmoDABw&usg=AFQjCNH8qF3DNaeeo4rCMhDdkOVaaLh07Q&bvm=bv.55123115,d.aGc The Aiwa Corporation is a consumer-electronics company from Japan which started in the early 1970's. It has its momentary popularity in the country for the comparable quality of its appliances particularly audio equipment at cheaper prices. In early 2000, the company plummets towards insolvency and was acquired by the biggest electronics company in the world, Sony Corporation. Aiwa was given a new lease of life as a wholly owned subsidiary of Sony. In 2004 however, 2004 Sony has shelved its support for the Aiwa brand as manufacture and distribution of Aiwa products were discontinued. Similarly in the Philippines, the Solid Group Inc. (SGI), the local company in charge of the marketing, sales and service of Sony products had also put off the marketing and distribution of the Aiwa appliances. By 2006, Aiwa products were no longer sold in the market around the world. Technically therefore, there exists no Aiwa Service Center anymore. However, Sony, its mother company and the Solid group in the Philippines may still provide repair services for Aiwa products. For service repairs of your old Aiwa appliances, you may call 330-1111 for service inquiries or email [email protected]. You may also contact the Sony customer hotline no. 02-8787600 or 09178077669 or email [email protected]. Sony Authorized servicve center 99 - 107qezon avenue , quezon city near welcome rotonda in between Ford & Burger King welcome rotonda 878-7600
4/25/2014 8:20:04 PM • Sharp... • Answered on Apr 25, 2014
0answers
Sharp cd dp2400 tray
Be the first to answer 4/11/2014 6:45:20 AM • Sharp... • Posted on Apr 11, 2014Be the first to answer
0answers
Cd dk890
Be the first to answer 3/26/2014 4:10:25 PM • Sharp... • Posted on Mar 26, 2014Be the first to answer
0answers
Sharp Multi-System Mini Component System Shelf System Logo
132 questions posted
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Audio Players & Recorders
Most Popular Question
sharp bh950 some reason come used work
  • Audio Players & Recorders
