20 Most Recent
Compaq iPAQ PA-2 MP3 Player Questions & Answers
Kids have put password acount on laptop and now
On the logon screen, press CTRL+ALT+DEL twice and you will get a different login window
Login as username = administrator
mostly probably you may have the password blank, else you need to hack into your machine.
Transferring from napster to creative zen v+ from acer aspire 1
Make sure you have the latest drivers updated. If needed, transfer songs from napster to media player and don't forget to sync you device and also if needed, go to control panel, and then to device manager, and make sure your device is reading, enabled, and working. You can also right click on the driver file and make sure it is NOT set to Read or Write Only.
Does a compaq ipaq mp3 player have a internal
Yes.
It got an inbuilt memory of 64 MB and it got expansion slot to expand the memory.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Compaq iPAQ PA-2
I have the same situation. Although it would have been a good .mp3 player to give to my daughter, I do not think it worth my (or your) time when they have higher storage and smaller bodies for cheap now days.
If you're hell-bent on making it work on those new OS's then your best shot is downloading
RioPort Audio Manager 3.3 (or later) because Windows Media dropped it's driver support after version 7 (it's version 11, now). RioPort is what I used before I got a hold of iTunes.
Good Luck!
Cannot hear sound
they might be muted or have faulty connections/leads
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
