20 Most Recent
RCA Lyra RD2765 MP3 Player Questions & Answers
Tags On My Mp3's On Device (RD2765) Aren't Working
The music files come from all kinds of sources, so some of the songs may lack complete information. Serious music fans are always willing to
fix music tags manually or automatically, and they may also want to complete the music tags of a song which they record from the Internet or elsewhere. Therefore, the music tagging problem has become more and more popular among the users.
As for fixing music tags, I recommend you a great program - Leawo Tunes Cleaner. The following guidance will take
Leawo Tunes Cleaner as an example to introduce how to fix music tags in detail. First you need to
Leawo Tunes Cleaner '
Leawo Tunes Cleaner for Mac and install it.
Run Leawo Tunes Cleaner, and choose Open Music Files.
Locate the song(s) you want find album artwork and click Open.
The software scans the songs automatically. You need to click Fix All at the upper right corner.
The program fixes all music tags and provides a preview. Click Apply at the upper right corner to finish the task.
For more insformation, check:
Music Tagger: How to Fix Music Tags
Wont turn on to download anything
have you tryed hooking it up to the computer and freeing up 20 megs? if you have then it could be a firmware issue goto their website and find the latest firmware and flashing utility and reflash it see if that helps
My rd2765 is not showing up on my computer
Hi roquehanzo...
Double left click "Hy Computer"...look under "Devices with removable storage"...Your player should be listed there..if not
Try this solution to your problem.
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
I cant format my usb,mp3 player?what should i do?
Go to my computer. Select your mp3 player and right click. Select format. Beware that this will also delete all files to run your mp3 file. I suggest if you just want to clean all the music of to just reset it back to factory settings.
I charge my mp3 and
so your battery is weak. if it is a lithium battery throw it away. Nickel based batteries (nimh or nicd) can be refreshed by a good battery charger.
The battery not charging all
It would depend on how you charge the device.
If you charge it part of the way, and then take it with you and use it, and repeat this many times it can cause this issue.
If this is not the case, you have a faulty battery and it needs replacing.
In future, drain the battery at least once a week and then charge it all the way.
Rca lyra rd2765a mp3 player
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
