20 Most Recent
Cobra Electronics MR F55 Questions & Answers
What is the recommended prop diameter and pitch for a 7.4L King Cobra OMC on a 245 Sundowner
props and made to suit the engine to do a certain job
they are pitched to maintain performance while operating in the torque range of the engine
To that end you have to talk with a marine specialist shop and discuss what you use the boat for, what speeds you want to operate at , operate in salt or fresh water, what loads you wish to carry
There are many pitches and prop sizes and all are engineered for a specific task
How do I remove the starter from a 3.0l cobra
cobra is telling me ford so if you are looking at the motor
the starter is on the left side under the exhaust manifold
it will have 3 1/2 in bolts holding it in make sure you un
hook the battery before removing the starter ///
the battery wire on the starter is a 5/8 or 11/16
wrench// that's all you need to remove the starter
i hope this helps you
bob
Radio transmits at close distance
If the radio device has a variable strength setting for transmission, set it at the higher value... for example 5 watt as opposed to 1 watt. Also, ensure you have a quality antenna. Radio signals are usually line of sight signals, so if there are many obstructions between the radio antenna and the receiver/listener, strength of signal can be affected.
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
