20 Most Recent HP Digital Projector sb21 Multimedia Projector Questions & Answers
I replaced the lamp in my sb21, but now the right side of the projection is dark. left side is clear and sharp but starts to go dark about midway across. Could the new bulb just need to be cleaned?
Try taking the lamp out and reinstalling it - it may not be all the way in. If this does not help, a polarizer or filter may be bad. It's going to be hard to get replacement parts for this old projector that is at least 11 years old. The only other thing I can think of is to try a factory reset - look through the menus until you find this.
10/3/2016 3:10:34 PM • HP Digital... • Answered on Oct 03, 2016
2answers
Color is very yellow - color temp setting does not affect
reset to default and try again
5/29/2015 11:19:28 PM • HP Digital... • Answered on May 29, 2015
How do I find the color wheel and clean it
The best answer I have found for this is listed here: http://en.wikipedia.org/wiki/Digital_Light_Processing If you scroll down the page, you will actually see a diagram as to whee the color wheel is located and, how it functions. Someone took the time to take pictures of the projector and the internals for use in showing how light emits thru it. Hope this helps.
5/29/2015 11:07:24 PM • HP Digital... • Answered on May 29, 2015
CONNECT TO MACBOOK AIR
That's all there is to it
8/7/2014 7:34:27 PM • HP Digital... • Answered on Aug 07, 2014
HP sb21 lamp
There is a very picky sensor on the lamp cover. When the lamp and cover are seated perfectly, your lamp will start.
9/8/2012 2:48:09 PM • HP Digital... • Answered on Sep 08, 2012
0answers
0answers
My SB21 projector worked fine
Welcome to FixYa.
The first step is to change or try a different projector cable. Though a projector cable may look fine on the outside, we are not able to see the inside.
Make sure also that you are correctly pressing the correct buttons to send the signal to the projector. Most laptops use the combination of "Fn" + "F7" (or F5) keys in the laptop keyboard to send the signal to the projector. Sometimes you need to do this twice or three times.
Keep me posted.
7/27/2011 6:20:36 AM • HP Digital... • Answered on Jul 27, 2011
Video image is mostly yellow. Just replaced bulb.
The Image Optimization slider button is on the All images menu. The range of the slider is from 0 to 10. The 0 end is labeled with an icon that looks like a piece of movie film. The 10 end has an icon that looks like a bar chart. When you move the slider, it changes how images are optimized. At setting 10, brightness and contrast are maximized. At setting 0, color reproduction quality is maximized. Settings 1 through 9 are intermediate settings. The default position from the factory is 10 for the computer input, and 2 for the other inputs (video, s-video, component-i, and component-p). It is assumed that people making presentations from a computer want high brightness and contrast, and people running video probably will control the room lighting more and want better color reproduction. The projector has two independent memories for the last set position of this slider. If you are watching from a video input, you might change the slider to 5 to get a bit brighter picture. From then on, the new setting of 5 will apply whenever any of the four video inputs are used. The computer input has an independent memory for the Image Optimization slider setting, which can be set only when a computer input is connected and selected. You can set the computer and/or video to anything you wish, 0 to 10. If you do not like the colors when using the computer input, you can try lowering the slider number. If the output seems unexpectedly dull, you might want to increase the slider. If the highlights (white parts) in video images look "pasted on" or "burnt to white" then you may want to lower the slider settings.
1/26/2011 5:13:15 AM • HP Digital... • Answered on Jan 26, 2011
Why is the projector looking for a signal?
Need input signal from Computer or DVD player. You will have to select RGB or Video in the projector menu.
8/10/2010 4:32:07 AM • HP Digital... • Answered on Aug 10, 2010
Our HP 21 Digital projector has a green tint when
Hi it sounds like you have a ne missing on the VGA feed to your projector, try using a composite lead to see if it is the same it should be ok also you can try using the menu see if the white is white when menu is pressed if it is then it is the lead, it possible could be the VGA socket but i have never seen a faulty socket so unlikely.
Marc Engineer
6/17/2009 12:02:15 PM • HP Digital... • Answered on Jun 17, 2009
2answers
Can't use my hp sb21 with my Macbook
it works if you do it in bootcamp. but have to select external monitor instead of digital display under the intel graphics control panel. does anyone know of such an option under OSX?
4/10/2009 11:12:33 PM • HP Digital... • Answered on Apr 10, 2009
How can i know the projector lamp age
go to the menu , check information or lamp timer . u will get the lamp hours.
u can also physically check the lamp for melted filament, white deposit on reflector of broken filament to confirm
2/8/2009 7:16:29 PM • HP Digital... • Answered on Feb 08, 2009
3answers
My hp deskjet 2300 printer is not printing. its says in the desktop it is printing
  1. Click and select. (Settings) > Devices > Printers & scanners.
  2. Select your product and click Manage.
  3. Click Printer properties.
  4. Select the Ports tab.
  5. Select the Enable bidirectional support checkbox and click OK.
Or else google for troubleshooting.
4/20/2024 11:06:50 AM • HP Office... • Answered on Apr 20, 2024
HP Digital Projector sb21 Multimedia Projector Logo
Popular Tags
30 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
know projector lamp age
  • Office Equipment & Supplies
