20 Most Recent
Sanyo Xacti VPC-CA9 Digital Camera Questions & Answers
The sound is not recorded
Hi natalieaylet ,
Firstly i would recommend you to check if the microphone settings have been accidentally turned off , many times the sound is not recorded because of this issue.
Please don't let people experiment with your camera as they could do damage to your camera.
So where you felt there was a problem , you will have a big problem , as a result of experimentation.
If you feel that nothing works , even after changing the settings and restarting the camera, i would recommend you to dial the number provided on the user manual usually, which will help you with the nearest service center details so that you can get your problem fixed by an expert.
Hope this helps ...:)
My lens is scratched and
There's nothing you can do except to have the lens replaced. Trying to rub out a scratch would only result in the lens having a different focal point and would no longer work with the other lens elements in the assembly. This will probably cost more than the camera is worth.
Hi i have a sanyo
try to download them into computer and see if you have sound on them when you play back into computer ...if you do it means the issue is on the playback feature and probably the volume for playback in the camera is muted or low .If you do not have sound..than look into the camera menu and locate mic..and see to be turned on and its volume razed proper..I believe that if you do not find the mic..(it may have an external button to turn it on and off) you may look in the menu for factory settings ...or something called factory defaults reset ..and engaging them it will reset any mic related settings that may cause the issues..
Why won't Sanyo Xacti camera does not power on after being charged?
not car moved this to camera
no model told at all
the batteries are no good or connections rusty on most
many of these are 13 years old and sold as new by liars endless on the web .
models
vcp-nnn (lots )
DMX-nnn (lots)
the endless list is here.
what it uses inside who knows lacking model
the battery is bad, or allowed to leak and damaged connectors.
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.The manual is still online.Success
How to get my picture right side up
I'm thinking you mean it is upside down on the camera screen. ??? Old man told me one time. When you get tired of trying to make that thing work right - read the instruction.
Sanyo VPC-T1496 Battery issues
Talk to Kastar and tell them there battery messed up your camera. I am assuming the camera was working OK when you got it.
