20 Most Recent Sharp SF 2020 Copier Questions & Answers
HOW WILL I CLEAR SHARP COPIER AR 5516 WITH ERROR CH
make sure all the doors are closed & the toner catridge is full
4/21/2016 1:35:09 PM • Sharp SF 2020... • Answered on Apr 21, 2016
How will i clear code f2 40 for sharp ar5516
Enter sim 14 or 16 if not help change toner sensor or complete toner catridge
4/21/2016 12:34:05 PM • Sharp SF 2020... • Answered on Apr 21, 2016
I have a copier sharp 5731 that display code H4-01 ,how do i fix it
replace the fuser try this site for a start for parts Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/13/2016 12:57:31 AM • Sharp SF 2020... • Answered on Mar 13, 2016
Sharp AL-2020 - Copier Producing Copies with Faint portions at Top Middle and Bottom of Page
This if often a faulty toner issue. If you are refilling it might be time for a replacement carrier. Alternatively have you checked your transfer belt for areas of damage
7/5/2014 10:49:15 AM • Sharp SF 2020... • Answered on Jul 05, 2014
2answers
What does h5 code mean?
Hello sir; There have no H-5 error code in the manual, the only chance appear is when you make a automatic exposure adjustment.
12/23/2013 7:16:51 PM • Sharp SF 2020... • Answered on Dec 23, 2013
India xerox
Usually depends on the country and supplier
10/17/2013 1:26:24 PM • Sharp SF 2020... • Answered on Oct 17, 2013
I have a sharp sf2116 copier. when copying i am
problem is not the toner , could be the developer unit stopping at that point when it becomes feint and then no new toner gets to the drum, ORit could be the transfer section
10/9/2013 11:59:12 AM • Sharp SF 2020... • Answered on Oct 09, 2013
Sharp SF-2022 Photocopier prints nearly all black
developing unit malfunction
7/8/2013 4:26:19 PM • Sharp SF 2020... • Answered on Jul 08, 2013
Sharp sf 2120 user guide
Heres a link to sharp's manual download site. Good luck !http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
1/22/2013 8:02:25 PM • Sharp SF 2020... • Answered on Jan 22, 2013
2answers
I have a Sharp SF-2030 copier and it is diplaying a F1 code.
F1 FIRST OF ALL CHECK WHAT IS THE SUB CODE .IF SUB CODE IS 00 ITS COMMUNICATION ERROR BETWEEN MAIN BOARD AND FINISHER.IF 01 FINISHER SHIFT PROBLEM.IF 06 FINISHER MOTOR PROBLEM.IF 10 THAT IS STAPLER PROBLEM.DO NOT FORGET TO RATE THE SOLUTION.MIAN JEE
12/14/2012 9:50:55 AM • Sharp SF 2020... • Answered on Dec 14, 2012
3answers
Where is the drum &
Clear Drum Sharp AR 5520
7/2/2012 6:33:19 AM • Sharp SF 2020... • Answered on Jul 02, 2012
2answers
I have a aharp copier that is displaying the error
enter code 14 press copy key
10/17/2011 9:16:34 PM • Sharp SF 2020... • Answered on Oct 17, 2011
I have a Sharp SF-2020
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
8/29/2011 11:23:06 PM • Sharp SF 2020... • Answered on Aug 29, 2011
I have a sharp2030 photocopier,
If you are getting no toner on the paper the charging unit which charges the paper to transer the image from the drum is faulty,Check all the removeable charging units which comprise a very fine wire stretched acos the paper path.Otherwise contact Sharp giving them service code
4/29/2011 11:00:57 AM • Sharp SF 2020... • Answered on Apr 29, 2011
0answers
We have a Sharp SF 2027 copier can we fix it
What is problem? I can help you.But you do not write any problem.
3/10/2011 7:54:22 PM • Sharp SF 2020... • Answered on Mar 10, 2011
84 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp al 2020 copier producing copies
  • Office Equipment & Supplies
