20 Most Recent
Sharp AR-M277 Digital Copier Copier Questions & Answers
Code f2 04
sometimes it is just your toner chips malfunction
Light copies
Clean the optical part components:glass,mirrors,lens,and change PC Drum.
I have a sharps printer
press system settings, admin password,default is (00000)-energy settings, set auto power shut off timer and preheat mode up to 240mins (4hrs)
Does a Sharp A RM
AR-M277, 237, 257, 310 models do not have hard drive. The data is stored in memory. If you have any job pending and turn the power switch off, the data will be deleted.
Our sharp ar-m277 is a
check the network ip of ur computer .is it on network or not.if not then u have to check the LAN port of ur pc as it may be fried.sometimes it happens.then u can add a lan card to make it work ,not costly .
but first check ur ip.
We had a power outage
Hi have you tried to doing a trouble clear, this is a fusing unit heating error!
Do you know how t do a reouble clear?
Sharp arm277 h3-11
Heat roller high temperature detection
Detail :The fusing temperature exceed 240oC
Cause: Thermistor abnormally .
