20 Most Recent Dell Inspiron 1545 156Inch Laptop I15453232OBK (Obsidian Black) 23GHz Intel CPU 2GB Memory 25 PC Notebook Questions & Answers
No recording capability
contact service center
4/23/2014 7:28:05 AM • Dell Inspiron... • Answered on Apr 23, 2014
Bios password
Read the Manual on resetting the Bios Password.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals and search them for Bios Password.
You can try the steps below if you like but there is no guarantee it will work on some laptops.
You will have to remove the power cord, remove the battery and remove the CMOS Battery that is located on the motherboard. On most computers you will have to take the laptop apart to get to the cmos battery. On some systems it looks like a silver nickel that you will need a small flat head screw driver to pop it out. On other systems it will be inside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put it back in and put the laptop back together. Boot the machine and you'll probably have to go into the Bios or System Setup because the system will have forgotten the date, time and password.
5/16/2012 1:07:25 AM • Dell Inspiron... • Answered on May 16, 2012
Computer will not boot
Will not boot? Does it come on and at least try to boot? What happens when you hit the Power Button?When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
5/3/2012 5:42:44 AM • Dell Inspiron... • Answered on May 03, 2012
0answers
2answers
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here. Larry Ng Jun 23, 2022 NO PC told (dell has 10000 models) no OS told, windows what"? no drive told. my wild wild guess is the boot drive is locked. and you are attempting and ******* act. to it. like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails) no real goal told, but the nebular "install HDD" one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact) but the boot drive , change out is far far far more complex. and you never not told that. you want to mess with the C: drive? now let me guess the real goal (sad I must) the OS drive windows is failing ( common) and some lil' bird told you it needs a new boot drive, and then fail to say so here. okay I will bite. 1: buy a new SSD (hdd fail and are slow) 2: buy a new OS, from MS. or get free w10. (ask how) 3: then put in new SSD, 4: run the w10 installer media (it is free) 5: load w10 to the SSD fresh 6: answer the silly 30 questions it asks. 7: and click activate. (buy it) ..
6/23/2022 1:35:37 PM • Dell Inspiron... • Answered on Jun 23, 2022
How can I log on after having lost master password?
to what, no PC told no OS told windows locked you out BIOS admin, or HDD locked or power on locked out?<< all bios. or bitlocker locked out or any of its 100 clones
5/2/2022 2:40:49 PM • Dell Inspiron... • Answered on May 02, 2022
How do i change admin password
can;t log in now or what? what does change mean, lost it and now can not get in or means just want to change it , logged in. NO PC told and NO OS told or if bios admin or windows admin. bios or windows. both are hacking./ if lost. so google the cure.
5/2/2022 2:36:54 PM • Dell Inspiron... • Answered on May 02, 2022
My email will not open. Just circle going around. I have windows 10 with windows live mail 2012
so PC runs perfect right , just email bad. right? your browser can visit many websites ok? yes /no? if yes, good , if no, wifi is dead. fix WIFI forget email now. so can you login at life.com or not. live is both email and more even the cloud and the STORE. if only live fails ask MS to fix it. live is them, them only
5/2/2022 2:23:52 PM • Dell Inspiron... • Answered on May 02, 2022
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT the PC must be running, or use the paper clip hole trick. (if PC is dead or tray jammed) google that. clip trick the dell manuals covers this
4/30/2022 3:47:20 PM • Dell Inspiron... • Answered on Apr 30, 2022
I want authentication code
add one noun to what. vast things have it, name one, please.
2/6/2022 3:52:06 PM • Dell Inspiron... • Answered on Feb 06, 2022
When trying to use office word starter I get asked for user name and initials every time I log on. After that it goes to the Microsoft Office window and I have to accept the license agreement.
ask at Microsoft.com forum , there? or learn that if PC had this new, it is in fact crippleware. and will nag you until you buy it or do the rent things, 360 jive. best is buy it and set it up like you went. even 2007 runs here on w10. office. the PCs most on earth new, come with free but fully crippleware. as do vast other bloatware loaded on new PC. I erase all that junk and set up my own things paid and licensed.
2/6/2022 2:34:25 PM • Dell Inspiron... • Answered on Feb 06, 2022
How to delete bookmarks
google dead ? first off my PC has 4 browsers. all 4 different answer. IE11 ( or OMG 1 to 10 ) Edge Chrome. Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete. learn google like google IE11 bookmarks delete. and read, millions of hits world wide all true.
2/6/2022 2:13:23 PM • Dell Inspiron... • Answered on Feb 06, 2022
Have a inspiron 17 and trying disable the admin and system password in the bios
dell.com ask or google how, this is called hacking so hack away, we won;t watch, grin.
2/6/2022 12:54:17 PM • Dell Inspiron... • Answered on Feb 06, 2022
tip
Fix Heating issues with dell laptop
Tips to fix heating issues in Dell Laptops: Inspect and clean the air vents and fans Restart the computer Update the BIOS and Chipset driver Download and install Microsoft Windows updates Run a hardware diagnostic test Use Dell Power Manager to manage thermal performance (applicable for select Dell laptops) Improve efficiency to reduce heat Perform a Windows System Restore Restore the computer to factory defaults
3answers
I want to delete my shtyle.fm account plz help me to delete acoount permanently
I don't know its solved or not but here's the method. Step 1 : Login to your profile of shtyle.fm Step 2 : Move your cursor to the "you option "or "your profile option". Step 3 : There, You will see the link of "Account Settings". Step 4 : Click on that link and you will see "Delete profiles and friends" Option There. Click on it. Step 5 : After that you will see the information that why you should't delete the account and bla bla bla. Step 6 : Just click on the continue button. I highlighted the link in below given image. Click there. Step 7 : Now you will see the box where you can enter the reason why you want to delete your shtyle account and profile. Enter reason or leave it blank and click on delete option. That's It. Your account is deleted. When you try to login with the same credential again you will see this. If you see below given error then your account or profile is deleted. savee-undefined-undefined-0.pngSource : Youshouldlisten.com
7/10/2021 12:07:43 PM • Dell Inspiron... • Answered on Jul 10, 2021
3answers
Upgrade memory on dell inspiron 3268
From what to what ................................
6/14/2021 2:32:36 PM • Dell Inspiron... • Answered on Jun 14, 2021
I have a Dell Inspiron 14 5000 2-in1 laptop that won’t boot on when starting up. I get a blank screen. How do I get past that screen.
It might just be the fact that your laptop has died on you. Or it could be that the screen has quit working and needs to be replaced.It could be an issue with the hard drive.
2/27/2021 12:45:15 PM • Dell Inspiron... • Answered on Feb 27, 2021
2answers
My dell inspiron 15r used to play a video clip
Have you tried different programs? Such as VLC?
2/20/2020 7:26:41 AM • Dell Inspiron... • Answered on Feb 20, 2020
Delll Inspiron 1545 - after a bit the screen fades
I'm sure you already have checked this but it's worth a try. Did you check in the control panel area under the Power Options for how long it's set to time out the screen? Sometimes people don't know that they can change how long the screen will stay lit, then time out. In that same area you can set the time for timeout of the Hdd to sleep, closing the lid and what the power button actually does.
10/5/2019 5:45:00 AM • Dell Inspiron... • Answered on Oct 05, 2019
Dell Inspiron 1545 156Inch Laptop I15453232OBK (Obsidian Black) 23GHz Intel CPU 2GB Memory 25 PC Notebook Logo
6 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
no recording capability
  • Computers & Internet
