20 Most Recent
Sharp CS-2850 Calculator Questions & Answers
Casio FR-2650A
the tape goes into a small slot on the backside of the machine, not in the clear plastic cover. Install the roll so the paper rolls off the bottom, not over the top. Folding the paper back about 2" does help you get it through.
I have a SHARP Compet
With this type of calculator, you have it right to display 2 decimals. As far as for is to dislay 5.10, you will need to actually hit the decimal point where you want it in order to display it that way.
Casio FR-2650A
I have lost my manual. I can I thread my Casio Calculator FR2650a?
Ribbon
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=41ac1440b5ce70c501c116910d777461&q=Sharp+CS-2850
you can find ribbon replacement in manual above.
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
