20 Most Recent
Canon imageRUNNER C5800 Copier Questions & Answers
E077 Error
Hello; that is secondary transfer roller home sensor defect replace it.
1/30/2019 6:33:31 AM •
Canon...
Answered
on Jan 30, 2019
How do I replace red cartridge? Found the
It should be under the same main compartment as where you found the red toner, it may just be hidden from your view at this point. Can you take a picture of what you see?
8/31/2013 9:26:21 PM •
Canon...
Answered
on Aug 31, 2013
Error 073 0001
Hello; that's transfer drawer connector problem, check the connector.
10/8/2012 3:51:02 PM •
Canon...
Answered
on Oct 08, 2012
E000079-0001
The E079 error code indicates the home position of the outside heating roller (engagement) home position sensor does not get detected. The outside heating roller (engagement) home position sensor does not go off.The detail code 0001 indicates the home position sensor does not go on within 5 seconds after the start of the home position search.The error code does not reset after the machine's power is turned off and on again.Check the position of the outside heating roller home position sensor's (PS22) flag. The flag can easily be moved out of position or broken during transport.Note: the parts manual refers to the outside heating roller home position sensor as PS66 rather than PS22. (See figure 810 page 2-156)
4/30/2012 5:26:51 PM •
Canon...
Answered
on Apr 30, 2012
Need to adjust the Settings on the Colour Mode to
Hello kthomas803,
You are smart to see this and respond. Even "black'pen ink has red pigment in it and although the human eye can't see it the copier can and counts that as a color copy. Hit the reset button so we know we are at the base configuration of the device.Now select black as the mode for the device as if you were about to make a copy.Now locate the "Aditional function" button to the right of the display.You will see a menu and I believe on your device the top right tab will say copy settings.Select it and scroll till tou see the "standard settings" key.Select it.The 2 options should be store and initialize.Select store and hit ok in he lower right corner.Now back out to the main screen which will require a couple of exits/resets.Now that you are back to the main copy screen select auto color.Press reset (yellow button).Your copier should now have gone back to black.Hope I have helped you,and have agood day.Please let "FIXYA" know if I helped. SPINAL
2/18/2011 9:46:30 PM •
Canon...
Answered
on Feb 18, 2011
