20 Most Recent
Canon PC-795 Copier Questions & Answers
Code E602-0001
E602 error means that there is a Hard Disk Drive problem ( 2.5inches Toshiba HDD that you should order to Canon, only a few models of HDD works on this machine )
Regards, Mug.
Auto doc feed does not activate
two possible problems :- check the connection of the document feeder - check the sensor on the document feeder that triggers the pickup - check the clutch of pickup roller
Canon PC-795
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply!
Good Luck!!!
I have a PC-795 the
throw the finger screw away. packing for the mirrors. look at the exp lamp are the ends black. if so change the ex lamp. causes jam at regi. otherwise change the feed clutch
How to change toner
allright here is where it is on the pc 940 series so i would have to guess that it would be the same on yours as well..... open the copier up like a **** shell. then towards the bottom of the v shape on the right hand side on the upper half is wehre you will find the toner/drum unit i believe. all you need to do is slide it out and put the new one in place.
Paper is jammed inside, probably
at the back of the printer there is access door.you will have to remove the door slowly and you can remove the paper easily.try it slowly.thanks.
please do rate the solution.thank you for using fixya.keep updated.
