20 Most Recent
Casio G-Shock G511-1AV Wrist Watch Questions & Answers
Changing batteries on a Casio G-Shock Cockpit watch
yes. wrong battery possibly...395/399 = SR927SW/SR927W
The 395 is a lower power output but same voltage (1.5v). The power spike of shorting might have caused a spike in the watch electronics.. make sure they are right polarity too. These batteries are not high current items, but maintain their voltage over the 5+ year lifespan. The S and SW are basically interchangable except for the higher amerage output.
I dont know how to
Press the "mode" button (bottom left) until the display says "HS" then press either the top right or bottom right button (depending whether you want to advance or ****** the hands) until the hands point the correct time.
When you have finished, press the mode button until the display returns to normal.
If you have any problems, (I have given you instructions that apply to my Casio, which is a different model, then you can get instructions for your model from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
How do you change the time dial on the g shock
You can get instructions from the Casio web site.
Go to the casio
watches;
Accept terms
Read
Had a new battery put in, digital worked but not
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get
cheap wow gold with the lowest price wihit in
10 minutes' fast delivery and you also can enjoy first class service
for your login.
Adjusting band on Invicta 4901
I was having the same problem with mine. Even though the band has arrows, those really are screws in the band. Two really small screwdrivers and you can take out the unneeded links. They are in there really tight, so expect some resistance until they pop loose, after that its easy.
