20 Most Recent
RIM Blackberry Curve 8900 Smartphone Questions & Answers
App error 532
Read the MANUAL and then operate have a good day .. thanks Vijaya
I cant turn my blackberry on
Try removing the battery then put it back in with the charger also plugged into your phone. Then try the power button.If it's not working ask at a mobile phone repair shop for help.thankscraig.
Blackberry 8900 won't turn on
Try to test or replace battery.... i need to know the history of what happen so that i can easily solve it for you...
How to tether a blackberry smarthphone?
Hello, Usually for tethering it depends on the carrier and if they support that feature .Also it may have an additional cost on you data plan . hope this helps !!
Sim not allowed on blackberry
Hi, your Blackberry mobile phone has been network locked. You need to unlock it from network restriction to be accessed with any GSM SIM card. To unlock your Blackberry mobile phone, you need the unique unlock code. You can get the unique unlock code for your Blackberry mobile phone from
www.SimpleUnlocking.Com at affordable cost with free unlocking instructions. good luck mate.
Jvr error 102
If you get "JVM Error 102" when starting your Blackberry, read this before you wipe everything!!I had spent hours searching for a solution to this problem (I even went to my service provider) and all I could find was that I would have to wipe the contents of my phone and start all over again -- tough luck if I didn't have backups for my contacts, appointments, program data, etc. What it comes down to is that the JVM 102 error means that a .cod file on your phone seems to be corrupt, so the phone refuses to load it. Why wipe everything for one bad file? You might not need to! Follow these steps:Download JL_CmderConnect your phone to your PC using the USB cable that came with it.Run JL_Cmder and select option 2 (event log)Scroll to the bottom of the log and look for "JVM Error 102." The line before it should tell you exactly what file is causing the error. It might look something like this. Save the file name; you will need it later.Go to Start > Run, and type "cmd" then press Enter.Change directory to the JL_Cmder installation folder.e.g., type: cd "C:\Program Files\JL_Cmder\" and press enterType the following command to remove the offending file:javaloader.exe -u erase -f FILENAMEwhere FILENAME is the name of the .cod file.Disconnect your phone from your PC and restart it. This might not be a permanent solution, but it should at least let you boot up your Blackberry so that you can back up all your data before reinstalling everything.jed neal
Blank white screen
Karim, read follow :identifying problem : this is sound me hardware problem,on LCD area; Causes :normally this happen by water damage , Solution :Clean with alcohol the LCD area on board, and let it dry for 4hours, it will start working normally.Material need :screw drivers tools for device, Brush,and alcohol.Notes:if you don't know how to assembly and dissembly the device search on you tube.com but if are you not able to do this at home, please don't try without supervision of technician,give some official repairer to fix for you.
How to sync a found phone
Synchronize to what? The phone will have the persons info on it why not return the phone and do the right thing.
My scroll dont work
try a hard reset of your phone. Dont forget to back up phone data..If still problem occurs contact to nearest customer support centre.
