20 Most Recent
Bose RC-18S Remote Control Questions & Answers
Bose remote
I need to program the remote to be able to use it with other appliances.
My Bose remote control RC28TI-27
Did you find a solution? I unscrewed the screw under the battery compartment lid near the rear end of the remote. The rattle is a broken radio frequency antenna. A replacement for this ancient remote is $89 plus shipping and handling. Supposedly the Bose systems can also be programmed with some universal remotes without rf antennae.
Remote rc25 not working
Check its infrared emission first. As it is new, the only possibility is with the failure of infrared LED inside it. If you wish to get more details about how to check a remote control,
check this link, and pull up older posts there.
How to change aspect setting
Enter its picture setting option. Press menu button, and surf through the menus to get this window. Here you can adjust the aspect ratio.
Doesn't work
Inside the remote is a ferrite antenna wrapped with a solid copper wire. Over time this large wire solder point cracks. I've had one that rattled. Carefully pry apart the remote and resolder.
