20 Most Recent
Bose Solo TV sound system - Black Questions & Answers
Bose solo sound system
Does the Bose remote work at all? New batteries may fix the problem.
Logitech Harmony universal home theater remote and app This the best remote control you can ever have for your system. It is amazing. No need to look up codes since the remote is programmed all at once for every component you have and it's done online at their website. Want to change or add a new component? No problem....just log back on to their web site and edit your settings.
Can you turn it on without the remote? My dog got a hold of the remote and I need to turn it on so I can try to program it to our cable remote.
? 2:12
https://www.
youtube.com/watch?v=QQziZ3w6z0A
Jun 22, 2015 - Uploaded by Lisa Tiffany Knowles
Learn To Bose Solo TV Sound System Review Read More reviews from Amazon Buyer: ... I received this sound system withno knowledge of what it really is. ... The rep that I worked with (they assign you one person to talk to--a real. live person who emails you ... bose solo tv sound system universal remote
worldwide.
bose.com/.../en_us/web/
solo.../page.html
Bose CorporationThe Solo 15 and Solo 10 series II systems dramatically improve television sound. ...Follow these steps to program your Bose® universal remote to control the other ... high quality home theater sound from your Bose system, you should turn off
No power to my bose box?
Check the fuse.
Take a look at the youtube video on another model Bose3-2-1...
It might help you. you should get local fuse depending on your country voltage
Can I use my BT youview remote to control my Bose solo,if so what is the code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Will not power up
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
