20 Most Recent
Kyocera KM-F650 Plain Paper Laser Fax Questions & Answers
KM-F650 fax machine only printing part of fax
I don't believe there is anything wrong with your fax machine. I think the receiving party may have a DIGITAL phone line.
If you can make a full copy with your machine then, your machine is OK.
Kyocera km-f650 keeps saying self testing...
Open the top cover and remove the toner cartridge.
Unplug the power cord
hold down the ENERGY SAVER KEY while plugging back in
display should say RAM INITIALIZE
scroll down to SHIPMENT SET
press SET
press 2
Wait for the machine to reinitialize.
PROGRAM FAX
Press
Function
72
set
1 touch
press 01 on the softpad
type in phone number
set
type in name
set
continue with 02 or press stop
Abnormal Toner Usage
I called Kyocera suppor today. They say this is a known problem with the sensor that a dealer has to fix.
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
