20 Most Recent
Lenovo IdeaCentre H215 PC Desktop Questions & Answers
Bois on d h215
Are you trying to enter (get into) BIOS?
This is for another model of Lenovo on the Lenovo.com website, but it will likely still work:
How to enter IdeaCentre Q700 BIOS setting screen
To start the Setup Utility program, do the following:
1. If your computer is already on when you start this procedure, shut
down the operating system and turn off the computer.
2. Press and hold the F1 key then turn on the computer. When you hear
multiple beeps, release the F1 key.
To start the Setup Utility program, do the following:1. If your computer is already on when you start this procedure, shut down the operating system and turn off the computer.2. Press and hold the F1 key then turn on the computer. When you hear multiple beeps, release the F1 key.
8/29/2014 8:42:55 PM •
Lenovo...
Answered
on Aug 29, 2014
Will not exit power saving mode
turn off computer hold down power button with plug out in back for 30 secondsrestart computerlet me know how this works
5/27/2012 10:06:05 AM •
Lenovo...
Answered
on May 27, 2012
IdeaCentre B300 power failure
first check if there is power failure in your locality
check if switch is on
check if UPS is working
check SMPS
if sms ok then check motherboard
could be static current in ram
2/29/2016 3:54:30 PM •
Lenovo...
Answered
on Feb 29, 2016
Touch screen not working
Verify the driver is installed for the touch screen. Go into the device manager to verify the driver.
6/16/2015 2:07:21 AM •
Lenovo...
Answered
on Jun 16, 2015
When turn pc monitor no signal
Verify all the cables are seated. You may also have a problem with your graphics hardware or drivers. If you get the BIOS screen typically signified by the manufacturer logo, press F8 to enter safe mode. If that works then it is most likely a driver issue.
6/16/2015 2:05:41 AM •
Lenovo...
Answered
on Jun 16, 2015
Web pages and programs are to large
Two possibilities: your pc's resolution is not high enough (which means you need to go to the desktop, right click anywhere in the blank area, select screen resolution, and change it to something higher) or, your browser is "zoomed". Hit ALT (the alt key) + V (for view) go to Zoom and lower the zoom factor.
I suspect the second is the problem as it's easy to zoom (ctrl+ and ctrl- will do it too).
7/18/2014 5:53:31 PM •
Lenovo...
Answered
on Jul 18, 2014
Puk code
WHERE DO I GET MY PUK CODE?
The PUK code is unique to your SIM card, so you can only get this from your mobile network.Sometimes they will give you this when you first get the SIM card, but not all networks do this. If you cannot find it, give your mobile network a call and they will be able to give you the PUK code after you have answered some security questions
3/23/2014 8:26:17 AM •
Lenovo...
Answered
on Mar 23, 2014
