20 Most Recent Johnson 1962 28 HP Sea Horse Outboard Motor Owners Instruct Manual RX 10C RXL Questions & Answers
0answers
2answers
2answers
1957 johnson outboard 10 hp fuel mixture ratio
https://www.google.com/search?q=1957+johnson+outboard+10+hp+fuel+oil+ratio What is the mix ratio for a Johnson outboard motor? Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio. Feb. 22, 2021
What is the mixing ratio for a Johnson outboard motor? - Mvorganizing.org
1/20/2023 10:22:40 AM • Johnson Boating • Answered on Jan 20, 2023
Owners manual for a 2002 50 horsepower Johnson outboard motor
marine shop---- online search
8/1/2022 6:27:37 PM • Johnson Boating • Answered on Aug 01, 2022
Hi, The tilt / trim runs very slow up & down after motor made minor impact. Motor is a 1998 Oceanpro V6 225. Your advice is appreciated, Thx Ted
With the issue being in both up and down, You may have bent the tilt/trim shaft(s) .. this is a job for a professional!!! sorry..
11/12/2021 4:56:40 PM • Johnson Boating • Answered on Nov 12, 2021
What operates the choke on a 1995 Johnson hj115
Push button ignition switch. Push the key IN while starting it.
11/12/2021 4:52:57 PM • Johnson Boating • Answered on Nov 12, 2021
What is the shift rod length adjustment on a 1988 110 HP JOHNSON ?
CALL YOUR LOCAL DEALER AND ASK THEM . i NEVER TRIED TO REMEMBER SUCH THINGS WHEN I HAD THE SERVICE MANUAL AT HAND
9/5/2021 2:55:05 PM • Johnson Boating • Answered on Sep 05, 2021
40hp johnson 2 cylinder only working on bottom cylinder
Check spark 1st, if ok check fuel line.
8/17/2021 9:17:15 PM • Johnson Boating • Answered on Aug 17, 2021
1984 Johnson 50 horse outboard runs great for an hour or two then will not run to make it back to the dock ???
Service the carburetor. Check cooling system. it may clogged. Run it in a tub and monitor heat buildup. When it stops running, do you have ignition spark? If no then the ignition coil maybe shorted when hot or it may have moved due to untightened screws.
7/17/2021 7:01:15 AM • Johnson Boating • Answered on Jul 17, 2021
98 50 hp Johnson. How can I remove tilt trim?
Check this thread on removing the tilt trim from your 1998 50hp Johnson motor: https://www.thehulltruth.com/boating-forum/490732-1998-johnson-50-hp-trim-tilt-repair.html
8/12/2020 4:22:11 PM • Johnson Boating • Answered on Aug 12, 2020
Why does my johnson 90hp outboard top carb feed one cylinder and not the other?
I don't know if this will be helpful, but I would check the compression and see if the rings are holding compression. If they are, that would indicate the cylinder should be drawing air in through the carb. If there is poor compression in the cylinder in question, that could mean that cylinder is not drawing in the air through the carb.
1/15/2020 6:10:59 PM • Johnson Boating • Answered on Jan 15, 2020
Finding Verity Johnson
Do you have a question? If you are looking for the journalist Verity Johnson, start with her website http://www.verityjohnson.com/ or a Google search.
11/19/2019 5:10:50 PM • Johnson Boating • Answered on Nov 19, 2019
I have a 1988 60 hp johnson The power tilt just stopped working Is there a fuse for the system It seems it is not getting power Where is the screw so I can manually lift the lower unit
See this. At about 4 minutes, he shows where the bypass screw is located. The fuse could be an inline one and is probably located by the control switch for the tilt unit, but it may be located somewhere else, depends on who wired it up.
11/4/2019 5:06:09 PM • Johnson Boating • Answered on Nov 04, 2019
2answers
Does bleed screw on tilt 70 hp Johnson come come out completely because when l screw tight it's leaking a little so does it need a washer
Great Work, It is a nice Post. It was very helpful for me. Thanks Keep it Up <a href="https://tutuapp.buzz/">Tutuapp</a> <a href="https://tutuapp.buzz/mobdro-apk-download/">Mobdro</a> <a href="https://tutuapp.buzz/whatsapp-dp-latest-images/">WhatsApp dp</a> <a href="https://tutuapp.buzz/instamp3-apk-download/">Instamp3</a> <a href="https://tutuapp.buzz/mobilism-apk-download/">Mobilism</a>
10/25/2019 1:51:21 PM • Johnson Boating • Answered on Oct 25, 2019
How much does a 2000 johnson 8hp 2 stroke weigh
About 58 lbs.
10/21/2019 1:42:33 AM • Johnson Boating • Answered on Oct 21, 2019
Install pinion gear on a 1987 120 hp johnson outboard motor
ok so you have removed the propeller from the leg so now you need to get a spanner to fit the nut then turn the engine clockwise to undo the pinion gear
10/20/2019 1:39:28 PM • Johnson Boating • Answered on Oct 20, 2019
1991 25 hp. johnson hard to start , floods easy
Hi ,check the needle and seat in the carburator it may not be not be cutting off the fuel when the carb is full as this can cause flooding into the throat of carb
8/25/2019 7:23:43 AM • Johnson Boating • Answered on Aug 25, 2019
Pulling apart a 1977 Johnson control box
This may help.
8/20/2019 2:02:26 PM • Johnson Boating • Answered on Aug 20, 2019
Johnson 9.9, serial C8160341, what is the year of manufacturier?
probably from the 90's
8/18/2019 7:20:24 AM • Johnson Boating • Answered on Aug 18, 2019
Johnson 1962 28 HP Sea Horse Outboard Motor Owners Instruct Manual RX 10C RXL Logo
1 questions posted
Top Johnson Boating Experts
NOEL
NOEL
jws1013
Are you a Johnson Boating Expert? Answer questions, earn points and help others
View Most Popular
Johnson Boating
  • Johnson Boating
Most Popular Question
am looking mount bracket support part
  • Boating
