20 Most Recent Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Questions & Answers
My trolling motor- 2007 70# Minnkota Powerdrive V2 seems to lose track of where it's at. I replaced both control boards and it still wanders off.
If you have already replaced the control boards and the trolling motor still seems to lose track of its location, there are a few other things you can check:
  1. The propeller may be damaged or bent, causing it to steer off course. Inspect the propeller for any visible damage and replace it if necessary.
  2. The motor's GPS sensor may not be functioning properly. Check to make sure the sensor is clean and free of debris. You can also try recalibrating the sensor according to the manufacturer's instructions.
  3. The wiring connections may be loose or corroded, causing intermittent power to the motor. Check all wiring connections for tightness and signs of corrosion, and clean or replace as necessary.
  4. The foot pedal or remote control may be malfunctioning, causing the motor to steer off course. Check the foot pedal or remote control for any damage or loose connections, and replace or repair as necessary.
If none of these steps resolve the issue, you may need to take your trolling motor to a professional repair shop for further diagnosis and repair.
2/24/2023 2:30:51 PM • Minn Kota Maxxum... • Answered on Feb 24, 2023
0answers
I have a minnkota maxxum 74lb thrust trolling
Good day , The next time the pin comes out have a close look at it if it has little raised grooves in it that is what is supposed to hold it in. if so put a little lock tight on the pin and push it back in it should hold again good luck Gordy
11/3/2017 5:44:49 PM • Minn Kota Maxxum... • Answered on Nov 03, 2017
Have a Minn Kota Riptide
Does the splice get hot when you are running the motor? If yes, then the splice could certainly be the problem. I would have replaced the wire completely. However, the problem more than likely is the controller.
10/29/2017 5:37:51 PM • Minn Kota Maxxum... • Answered on Oct 29, 2017
It won't work. Last time I ran it it it would work
did you check for power between foot control and motor?
9/29/2017 1:51:21 AM • Minn Kota Maxxum... • Answered on Sep 29, 2017
Old outboard ground wire melting
1. Short in the trolling motor itself 2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!! 3. Bad/dirty/corroded battery connections ..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
9/12/2017 12:13:04 AM • Minn Kota Maxxum... • Answered on Sep 12, 2017
I just purchased and installed a Minn Kota 70 PD
If brand new and not working properly, take it back and exchange it for one that works!
5/3/2017 3:50:23 PM • Minn Kota Maxxum... • Answered on May 03, 2017
Why it runs half speed wide open?
propeller could be slipping. It is sometimes held tight by a rubber washer that wears out.
5/23/2014 9:48:12 AM • Minn Kota Maxxum... • Answered on May 23, 2014
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
135 questions posted
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
View Most Popular
Minn Kota Boating
  • Minn Kota Boating
Most Popular Question
2007 minnkota powerdrive v2 seems lose
  • Boating
