20 Most Recent
Power Acoustik PTID7000NR Car Video Player Questions & Answers
I have a Power Acoustik
you may have two cd`s inside take the radio out and take it apart. inside the radio there is a realese for the cd tray but you have to have power to the unit for it to work. eject the cd from the front then hit the release on the inside its a little tricky but you should be able to find it
My sound keep going off. when i turn my car off n
Stereo device has been installed least powering off when vehicle turns off. In such a situation, either as manufacturer default of installation experts maladjustments. Observe the device that buttons makes power off without vehicles ignition. Two alternatives makes the devices rediscover the user's experience. First, discovering that the device powers with button becomes convenient. Else, arranging reinstallation of device to capture an impression. In a situation that the device least has the versatility features to capture power off from drivers ignition requires acquiring an alternate device.
I dont no how to
if the remote wire(blue) is connected to your dvd then the subwoofers should turn on automatically
Power Acoustik PD-624B 6.2-Inch Double-Din in-Dash LCD Touchscreen DVD Receiver with Bluetooth. The Radio cannot play any video, gives warning message.
Question edited for a lot more clarity, full make model (what it is)'.
Question moved from Televisions category.
The warning message may have been useful!
People don't realise that factory car audio is operated by and monitored by the Body Control Module (BCM) on a computer network. Your warning chimes and indicator clickers are generated by the BCM and played through the car audio system. The computer has no idea that this new device is!
Take it to an auto electrician or to an Alarm / Audio installer and see if their professional bi-directional grade scan tool computer can reprogram the BCM to ignore your device. Or just put the old one back.
I have a power Acoustik cpaa7dd double den car radio and I keep getting unknown disc errors
- Make sure the disc you are trying to play is compatible with the radio. The radio may not support certain formats or types of discs.
- Check the disc for any visible damage, such as scratches or fingerprints, that may be preventing it from playing properly.
- Check the CD player for any debris or foreign objects that may be preventing the disc from being read properly.
- If you are using an aftermarket CD changer, make sure it is properly connected to the radio and functioning correctly.
My power acoustik pd-620hb won't turn off
POWER/MUTE Button Press it to turn on the unit.Press and hold for 2 seconds to turn the unit off . Press the button briefly to Mute . Please note that the volume will be muted on all audio output connector.
I have a power acoustik pd 701 how do I play videos off my iPhone thru usb cable
- Smart Control enables select Mobile 8 models to communicate with the media player of most Smartphones and tablets
- Smart Control sends playback commands by the AUX cable connected to the headphone output of your smart device
- Control track selection, play/pause, and even answer incoming calls. AUX cable included. Variable Subwoofer Pre-Amp Output
- Play audio, video, and picture files through Mobile 8 from DVD, CD, or 32GB SD/USB flash drive. Supports MP3 & WAV audio files & MP4 video files, and JPG pictures.
- Safely make and receive hands-free phone calls, scroll contacts lists, and stream MP3's via A2DP from your enabled Smartphone. Most Bluetooth enabled Smartphones seamlessly pair
