20 Most Recent
Arris Surfboard SBG900 Modem Cable Modem Gateway 80211BG Wireless Adapter Questions & Answers
Modem suddently lost connection.
Please contact your Internet Service Provider if you are getting your provisioned speed according to your package. They need to run speed test for your account.
I can not find how to get my password
You can always bring the router back to its original default state by pushing the re-set button, located on the back of the device. It is usually a small hole about the size of a paper clip near the on-off button. While the router is powered on, push the point of a pen into the hole for about 10 second. Then you can go through the router menu and reset all the passwords, WEP keys and other parameters.
If you need help on how to access or set up the router menu, please comment. Also let me know if this information helped you.
J
Is the Motorola SBG900 cable modem gateway a
you should be able to set up a home network you will have to enable file sharing, if you run through the network setup wizzard in the control pannel it should be fairly straightforward
How to set up password
insert the disc supplied by your ISP internet service provider then enter the the user name and password you provided to your intenet service provider ISP then just follow the prompts
hope this helps
Pairing Router to Extender.
Please double check that each of your products are compatible with each other by either calling Arris or Netgear. You also review the netgear setup instructions after you've made the call if they're compatible.
This is the phone number for Arris: 1-877-466-8646
Thank you.
I have an arris router with suddenlink. i can login but i can't change my ssid because everything's greyed out. how do i fix that?
This can be done -- I've done it to my Arris modem router interface from Suddenlink.Make sure you have your original modem/router login info (typically this is something like admin/admin, or admin/password). You'll need this info in case there is an error and you need to reset your device. If you do this simple step-by-step carefully you won't need to reset and you'll be able to use the password or SSID you prefer with your device.To do this, the page with the grayed out field(s) must have an Apply, Submit, or other button that saves changes on the page.DO NOT TAKE THIS LIGHTLY.IF YOU EDIT THE WRONG GRAYED OUT FIELD YOU MAY NOT BE ABLE TO USE YOUR MODEM/ROUTER.Only do this for Names, SSIDs, Passwords, etc. Do *NOT* do this for other values--things are grayed out for a reason.1. Use Chrome or Firefox.2. Log into your modem/router.3. Right click on the grayed out field (which you want to edit) and select "Inspect" from the small context menu that appears by your mouse cursor.4. A complex looking set of window panes will open.5. The code for the grayed out field you selected will be highlighted in one of those windows panes.6. In that code look for something like:disabled(or)disabled="disabled"7. Click on that little bit of code text.8. Delete only that text:disabled (or)disabled="disabled"9. As soon as you click out of the editor and back onto the page you'll see the gray is gone and you can change the text in the field which is now editable.10. Replace the SSID, password, key phrase, or other information you're trying to change with the information you want there.BE CAREFUL ABOUT SPECIAL CHARACTERS OR SPACES.THEY MAY NOT WORK.11. After you've changed the text to be what you want, tap the Apply or Submit button on that page.12. The page should refresh now and record the new information in the field(s).If everything goes south (perhaps because you used a space or character which wasn't allowed), it's okay. All modem/routers have a reset button.
Registration code to activate a telus arris box
my guess is you forgot your ISP owns it
no country stated, no ISP stated nor your purpose here.
no model told, ARRIS. box.
plug it in
call ISP
speak
done. (only they do that, not you, you must ask them)
I own my own modem but must call them to even replace my box.
they configure it and is locked to ONE SERIAL NUMBER
JUST LIKE CELL PHONES ARE.
We have an ARRIS CM8200 router and Huawei modem,we have disconnected both items,can we password or code protect to block addicted game playing son access even if he does factory reset?
so why not ask this more clearly????what game not told. PC only topic,there are 2 types of games(besides console games) local on the PC and online games.there is only one way to block local games and that is take away the DVD gaming DISK (DVD) and then erase the game on the PC< (programs & features)Online games (like steam.com and vast others.:Some ISP can be setup to block specific web sites.ask your ISP this,(Internet Service provider)call em'?and this type of app.https://ht-vector.com/how-to-block-games.htmlor just on this 1 PC parental controlshttps://helpdeskgeek.com/free-tools-review/block-websites-for-free-with-parental-control-software/OR a better router , CAN BE bought that has this feature.you can add a list of blocked game web sites.or use DNS shield.https://helpdeskgeek.com/how-to/block-websites-from-your-router-or-using-dns/the problem is there are so many gaming websites.best is to jail the PC, until school work is donelock it up. (none told , is it big? or laptop)there there are , kid games using TV or CELLthe paths here today are larger.a custom DNS service is the best IMO as it protect the whole home from this.'the best is DNS, IMO.and for sure see the kids, browser history, to learn where they go. And now the list is bigger
I have an Arris modem model# NVG443B, I have power and my second light is blue (internet) but my third light down is red. What is wrong?
did it ever work before today, or fails after you moved to new home??so the Internet is dead? the manual covers lightsyou ISP needs to be called if resting router/modelfails (pull only AC cords from wall 15seconds or more and put back AC do not push reset buttons)NVG443B (is router + DSL modem combo)does ethernet work wired or just wifi dead. or both.not told.if both fail, call he ISP.RTM yet, on your Arris. 1: POWER LED 2: BLUE CONNECTED. (lan only)3: RED, No broadband connection detected ! CALL ISP.https://www.manualslib.com/manual/1428959/Frontier-Arris-Nvg443b.html
Arris surfboard sag-7580 ac blocks internet from my iPad only...
not told is google blocked (google.com)???????????
there are 1billion web sites now, are all blocked (LOL)_ or just one.?
best is boycott apple. for sure.(grin)
sounds to me (seems) that ipad is blocked by a smart DNS
not told
I use cloudflare. DNS, 1.1.1.1
there vast other DNS, but you didnt tell yours
and DNS can have HUGE parental blocks. to all evil sites
so in the surfboard settings set DNS top 1.1.1.1
to wide open generic, 8.8.8.8.
learn to access your router, RTM read the manual see its IP
and go there and set the DNS to any you like.
i like 1.1.1.1.
