20 Most Recent
Phil & Teds Sport Buggy Inline Child Baby Stroller Questions & Answers
How do i replace the
If you need to replace the foam, you need to take the handle bar off first. You will find screws, below and above the button, on the side of the handle near to where you can adjust the handle height. This way you can unscrewing the handle and replace the foam.
P&t front wheel sticks
Dear Jo B,Have you made sure that none of the fixing bolts or bearings that hold the wheels in place are stuck or seized? If they are not, then you might need to adjust any of the retaining springs that also fix the wheels to the rest of the stroller assembly (if these springs are indeed fitted). Any bearing grease, or even car axle/ CV joint grease will do fine. Some of these strollers also have a clip that you push down with your foot and it locks the wheels in certain positions. Check that this clip is not broken or misfitting, also check the brake bar too.Hope this helps and do let me know how you get on.Yours sincerelyOuszen
My tyres is flat and
Visit your local bike shop they'll pump up the tires and replace the tubes if required.
Replacement Parts Phil and Teds Stroller
hi .I'm in Queensland and have just placed an order for a front wheel n hood through my local stockist failing that perhaps get a cheepie off ebay and keep for spares!
