20 Most Recent
phil & teds Vibe Stroller Questions & Answers
How to take off rear wheels?
There
is a little push button on the metal bar that runs the length of the
stroller.
I heard about bearings have gone bad on phil and teds and
they (customer support) told me that need had to replace the entire wheel at 40 dollars a pop.
Hope helps.
We need a phil and teds repairer in nsw. we live
Karlisles if there's a repairer closer they'll tell you.
Workshop:
2 Haran Street,
Mascot, NSW 2020
Australia
(see map below)
Postal Address:
PO Box 7250
Alexandria, NSW 2015
Australia
Calls within Australia:
Ph: 1300 308 435
Fax: (02) 9700-9951
International calls:
International Phone +61 2 9700 9759
International Fax +61 2 9700 9951
Email [email protected]
The back tire maybe rubbing
hi
it sounds like the axle is worn ,replacements are available
here is a link to a uk based website that sells the parts for the vibe
http://www.groovystyle.co.uk/productpages/phil-and-teds/vibe-spare-parts.php
if you are not based in the uk there are plenty of website that do them including ebay
My Phil & Teds Vibe
Hi!
Assuming your tyres have the correct pressure, uncontrollable shaking in 3-wheeld swiveling strollers is usually caused by bearing slack.
Please check the front wheel bearing. It should allow the wheel to rotate freely but it should not be loose on the axle. (ie. It should not slide sideways on the axle.)
In this case you would need a new front fork/wheel assembly.
Please let a dealer have a look at it. As the Vibe has not been around for very long, you may still have warranty.
I hope this helps.
Erwin de Raad
www.babycare.nl
P&t front wheel sticks
Dear Jo B,Have you made sure that none of the fixing bolts or bearings that hold the wheels in place are stuck or seized? If they are not, then you might need to adjust any of the retaining springs that also fix the wheels to the rest of the stroller assembly (if these springs are indeed fitted). Any bearing grease, or even car axle/ CV joint grease will do fine. Some of these strollers also have a clip that you push down with your foot and it locks the wheels in certain positions. Check that this clip is not broken or misfitting, also check the brake bar too.Hope this helps and do let me know how you get on.Yours sincerelyOuszen
