20 Most Recent Numark CDn25 Professional DJ CD Player Questions & Answers
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
3/6/2013 7:13:23 PM • Numark CDn25... • Answered on Mar 06, 2013
How to connect a numark cdn25+g
This should help: http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
3/31/2012 5:14:21 PM • Numark CDn25... • Answered on Mar 31, 2012
Cdn-24 cd door wont open
Often the cause is a jammed CD or aa little belt that drives the carriage has failed or is slipping.
You need the OPEN the case to retrieve the CD if one is in there and check the mechanism does not have a problem. Some drives used to have a SMALL hole near the door that one would insert a straightened paper clip into straight to press a release... You might check for that.
2/25/2011 5:11:56 PM • Numark CDn25... • Answered on Feb 25, 2011
How do is fix my Numark m6 bleeding cross fader
/it's most likely a defective fader, but before replacing it, get a can of Deoxit5 or fader cleaner and spray inside the fader, then move it the full length os travel about 20 times to see it that clears it up.
7/10/2016 2:58:13 AM • Numark Music • Answered on Jul 10, 2016
Im just wondering if there is a company that works on numark C3FX, main gain and channel 1234 are not working properly ,if i put the volume up It will go up with it for a few se
sure tons!!! most every music shop that I ever been in (and that's a lot !!) that sold instruments and stuff has either an in house tech or a "guy" they go to , ask em as they get perks for referrals
1/5/2016 12:59:19 AM • Numark Music • Answered on Jan 05, 2016
0answers
Numark ndx800
Be the first to answer 11/13/2013 5:15:58 AM • Numark Music • Posted on Nov 13, 2013Be the first to answer
Anybody you know who restore
Most turntables require a new drive belt. The cartridge sometimes needs replacing. Cahngers require much more maintenance. Hardly anybody does this anymore... but if belt has deteriorated, that is DIY as you can find suppliers of the belt online.
8/19/2011 7:05:21 PM • Numark Music • Answered on Aug 19, 2011
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring. This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM • Music • Answered on Dec 31, 2023
What song did these lyrics come from. (You can set by the water but you just can't drink )
Are you sure you are quoting accurately? Could it be one of these instead? http://www.lyrics.cat/lyrics+lead+a+horse+to+water
12/27/2023 3:43:51 PM • Music • Answered on Dec 27, 2023
Line 6 spider ii head sounds like crap on insane red setting
It's a Line 6 and probably requires a software update from Line 6.
12/24/2023 7:57:43 AM • Music • Answered on Dec 24, 2023
Pricesof yMh PSR 9000 KEYBOARDS
  • Price:$1,099.99 on amazon
11/14/2023 7:53:13 AM • Music • Answered on Nov 14, 2023
Numark CDn25 Professional DJ CD Player Logo
Popular Tags
8 questions posted
Top Numark Music Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Numark Music Expert? Answer questions, earn points and help others
View Most Popular
Numark Music
  • Numark Music
Most Popular Question
numark cdn25 dual cd player when open
  • Music
