20 Most Recent Numark DM1200 DJ Mixer Questions & Answers
2answers
How to get new serial number for numark idj3
Once you make an authorized purchase you will be provided with a working serial number.
5/8/2019 12:00:40 PM • Numark DM1200 DJ... • Answered on May 08, 2019
2answers
Numark 360 21v 750ma Power Supply
Try the following sites
http://www.powerstream.com/power2.html
http://www.platinum-records.com/Numark-21V-750MA-AC-Adapter-Power-Supply-prod7509.htm
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
5/21/2015 6:08:44 PM • Numark DM1200 DJ... • Answered on May 21, 2015
0answers
0answers
HISS from Numark DM1200 mixer.
All interconnected equipment MUST be powered from the same receptacle or source. The XLR to the speakers should NOT have ground lift. The power for the mixer should come from where the speakers are and be routed alongside the XLR cables. All the other connected items should also be powered by the same source. The ground bounce within a building cannot only cause noise, but can rupture the input circuits of equipment. As an electrical engineer I don't know why manuals supplied with the equipment doesn't go into this more. The professionals at the big venues all know this as they have had to pay to get equipment repaired.
Now to get down to "hiss" once you get the other stuff straightened out, there are two things to know at the start: The first is that due to the statistical nature in electronics "noise and hiss" are among the laws of physics that we can't completely get around. The level of the hiss should NOT be objectionable however. The second thing is that proper level setup is important to minimize the effects of noise and hiss. You should be sending the levels to the powered speakers at near full line level into the line inouts, never mic inputs that some have. Using excess gain at the speakers will amplify any noise pickup on your audio lines. Next, at the mixer, try to keep all the level controls around 10 to 2 0'clock for rotaries and 70% for faders. Excess gain at certain stages will cause hiss to be objectionable.
3/19/2011 2:50:03 AM • Numark DM1200 DJ... • Answered on Mar 19, 2011
I'm not getting any sound out of one of the
The typical cause of this is a failure of the buffer IC (usualy a 4558 or 4570). This is a relatively simple repair that should be easy for any audio repair shop. The part will cost about $2-$4.
Post your location and I may be able to refer you to a local shop.
Dan
6/24/2010 11:20:46 AM • Numark DM1200 DJ... • Answered on Jun 24, 2010
Numark dxm power failure?
i'm having the same problem, just wondeered if you found any solutions to this?
12/3/2009 10:28:22 AM • Numark DM1200 DJ... • Answered on Dec 03, 2009
DXM09 MIXER ADAPTOR
Often the cord has broken wires. First try to repair the power supply.
Also check the connector in the mixer as they can get damaged by side pulls of the cord.
9/28/2009 4:31:10 PM • Numark DM1200 DJ... • Answered on Sep 28, 2009
I have a numark cd mixer and one of the cds wont
Where are you located? Also, is the mixer the problem or is it the actual player that is not working?
Thanks,
Dan
9/5/2009 1:40:54 AM • Numark DM1200 DJ... • Answered on Sep 05, 2009
I just put 12v through my dm950 mixer, it should
Where did you connect the 12Vdc to ?
8/1/2009 8:31:12 PM • Numark DM1200 DJ... • Answered on Aug 01, 2009
THIS IS NOT A NUMARK. need help with denon x120
I like the Pioneer DJM-600
7/21/2009 4:14:21 PM • Numark DM1200 DJ... • Answered on Jul 21, 2009
How do is fix my Numark m6 bleeding cross fader
/it's most likely a defective fader, but before replacing it, get a can of Deoxit5 or fader cleaner and spray inside the fader, then move it the full length os travel about 20 times to see it that clears it up.
7/10/2016 2:58:13 AM • Numark Music • Answered on Jul 10, 2016
Im just wondering if there is a company that works on numark C3FX, main gain and channel 1234 are not working properly ,if i put the volume up It will go up with it for a few se
sure tons!!! most every music shop that I ever been in (and that's a lot !!) that sold instruments and stuff has either an in house tech or a "guy" they go to , ask em as they get perks for referrals
1/5/2016 12:59:19 AM • Numark Music • Answered on Jan 05, 2016
0answers
Numark ndx800
Be the first to answer 11/13/2013 5:15:58 AM • Numark Music • Posted on Nov 13, 2013Be the first to answer
Anybody you know who restore
Most turntables require a new drive belt. The cartridge sometimes needs replacing. Cahngers require much more maintenance. Hardly anybody does this anymore... but if belt has deteriorated, that is DIY as you can find suppliers of the belt online.
8/19/2011 7:05:21 PM • Numark Music • Answered on Aug 19, 2011
Numark DM1200 DJ Mixer Logo
Popular Tags
19 questions posted
Top Numark Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Numark Music Expert? Answer questions, earn points and help others
View Most Popular
Numark Music
  • Numark Music
Most Popular Question
dxm09 mixer adaptor
  • Music
