20 Most Recent
Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo Questions & Answers
The remote will turn on but cant use any buttons
out on the control box, there is a service button. when your service guy is working on the pool, it should be on either 'service' or 'timeout'. in either of these modes, your remotes will not work and the timers are disabled. go to control box and set the system to 'run'
Set a program for pool mode on
go into set up then programming highlight the item you want to make a program for set on time and off time if you want it to run continuously start time 2:00am to 1:59am it will go off for 1 minute then start back up
My jandy pda assistant does respond and sometimes
try changing the channel to one or two numbers higher they come from the factory on number 5 hold the up and down arrows for 10 seconds it will show channel up or down change channel then go to the antenna take off the front cover and move the little button to learn when it promps you to turn back then it should connect
Jandy pda ps6 handheld just
try turning off the aqualink and PDA then turn on the aqualink then PDA if same happens check the 4 pin red plug inside the top panel if plugged in check the wire to the antenna if not cut or loose open the antenna panel to see if red and green lights blinking if not check to see if you can change channels if you cannot get to work put system in service and you can control spa that way
Jandy pda stuck on waiting mode
try changing batteries then shut system off turn back on then turn on PDA if still the same take off front top cover of aqualink make sure 4 pin red plug is connected and tight
