20 Most Recent Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Questions & Answers
2answers
Spa drains when turned on
The problem is in your plumbing. Someone put a valve in an incorrect position. I would have to see a picture of your plumbing but if you can follow the flow of water. When you put it in spa mode, look at which valves turn and which ports open up. If it is doing anything other then sucking water from the spa and returning it only to the spa, then that is why it is draining. Again it would be great if you had a picture. What I have seen before is somebody plumbing in the pipe for a pool cleaner after the valve that send water to the spa. This would result in water from the spa slowly draining out of the pool sweep line. Good luck.
9/25/2022 4:55:30 AM • Jandy Aqualink -... • Answered on Sep 25, 2022
Viron connect 10
how do i remove a fault 1 indication on the solar heating screen
12/1/2017 1:30:02 AM • Jandy Aqualink -... • Answered on Dec 01, 2017
Freeze protection interrupts spa operation in cold weather
There is NO WAY to override freeze protection. Removing the air temp sensor when in spa mode via a relay may be your only option.
5/3/2017 10:04:23 AM • Jandy Aqualink -... • Answered on May 03, 2017
0answers
0answers
0answers
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
246 questions posted
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
ZJ Limited
ZJ Limited
john h
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Jandy Pool & Spa
  • Jandy Pool & Spa
Most Popular Question
jandy hand held reads wrong wrong pool
  • Pool & Spa
