20 Most Recent
Concept DVD-168C Car Video Player Questions & Answers
Subtitle removal
There is a subtitle button on the remote that you can push to remove the subtitles. EASY FIX.
When i put a dvd in it says unable to read
Either the player is stuffed or the dvds are in the wrong format Try running a head cleaning disc through it there maybe dirt on the laser pickup apart from that its off to the dealer but be warned it's probably cheaper to buy a new player than get your one fixed
Screen won't play movie
sound like the wire to the parking brake may not be getting a ground.if it not get a ground it will no show a picture on the screen. it so you cant watch the dvd while driving.
Cocnept 168C DVD Player
I had the same problem. I had to take the cover off and mess with the tray. It was as if the tray had slipped back a bit and so it was not sensing the DVD. I pushed it forward and heard a click and it worked after that.
Loading Error then reads NO DISC
the disc cleaner is not exactly clean your lens! much better to open your DVD and you clean the lens with 100% cotton or cotton buds then slightly touch your cotton to lens in clockwise to remove the dirt!
Concept CC-504 Amplifier. Does anyone have a manual for it please?
To the OP 'Anonymous'. There is no manual available.
https://www.google.com/search?q=concept+cc-504+manual
For
Cricket Wireless. Here are the
specs:
4 Ohm Stereo Power (RMS): 50W X 4
2 Ohm Stereo Power (RMS): 75W X 4
4 Ohm Bridged Power (RMS): 150W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Remote bass level control "port" (remote RM-100 available separately)
Platinum Connectors
Length: 13"
Width: 11.66"
Height: 2.37"
What is bias?
Please check this https://www.google.co.ve/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/Tape_bias&ved=0ahUKEwjyy4nc7_vWAhVC6yYKHcwKAN0QFghdMAw&usg=AOvVaw3nn4G9wnIbrtGhPww_VaaU
