20 Most Recent
Concept DVD-168T Car DVD Player Questions & Answers
Concept CC-504 Amplifier. Does anyone have a manual for it please?
To the OP 'Anonymous'. There is no manual available.
https://www.google.com/search?q=concept+cc-504+manual
For
Cricket Wireless. Here are the
specs:
4 Ohm Stereo Power (RMS): 50W X 4
2 Ohm Stereo Power (RMS): 75W X 4
4 Ohm Bridged Power (RMS): 150W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Remote bass level control "port" (remote RM-100 available separately)
Platinum Connectors
Length: 13"
Width: 11.66"
Height: 2.37"
What is bias?
Please check this https://www.google.co.ve/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/Tape_bias&ved=0ahUKEwjyy4nc7_vWAhVC6yYKHcwKAN0QFghdMAw&usg=AOvVaw3nn4G9wnIbrtGhPww_VaaU
250W, 8 Ohms speakers on 150W, 6-16 Ohms Amplifier.. What is the effect of this?
If your amp states that it will support a range of 6 - 16 ohms, an 8 Ohm speaker will work fine on it. If the speakers you hook up to it are lower than 6 ohms, it may work until you turn it up, then it will either shut down or burn out the finals. If you hook up a speaker that has a higher than 16 ohm, it will not get very loud, and it shouldn't hurt the amp.
